Sponsored by:
Sponsored by:
interior lights pulse when passenger door is opened
Old 06-11-2009, 01:27 PM
fkuk's Avatar
Default interior lights pulse when passenger door is opened
when i open the passenger door the interior lights pulse this does not happen when i open any other doors
could the problem be that the lights in the doors do not work?
is there a place that i should start looking to fix the probelm
Old 06-11-2009, 10:27 PM
ltooz_a6_a8_q7's Avatar
Mine does the same thing on rear passenger side door only or may be both rears? Never had time to check it out and forgot all about it. One of these days... :-)
Cheers,
Old 06-12-2009, 03:01 AM
Kneale Brownson's Avatar
Each door has a switch that turns the lights on when opened. You may have corrosion or a short in the switch or in the wiring to the switch. There is a relay that shuts the lights off some time after the doors are closed. My first guess is the door switch is corroded or damaged so that it is sticking part way in its moving out (little spring inside) when the door is opened and the relay doesn't get the correct signal.
Old 06-12-2009, 06:25 PM
fkuk's Avatar
where is the door switch located
Old 06-13-2009, 05:07 AM
I'm stumped.
All my earlier Audis have a plunger-style switch on the door frame that gets compressed when the door is closed and springs out when the door is opened, but I can't find anything like that on any of the door openings of my S8.
There's some sort of ultrasound security system on the newer cars that somehow reacts to the opening of a door by activating the interior lights relays. So you may have some corrosion on the relays.
Old 06-15-2009, 07:19 AM
jfrahm's Avatar
I thought there was a switch in the lock mechanism. I suggest a search, the disco lighting is a common enough problem.
-Joel.
Old 06-16-2009, 04:43 PM
tozoM8's Avatar
The switch is in the lock.
Old 06-17-2009, 12:43 PM
fkuk's Avatar
is it easy to get to the lock and how is the sensor connected to the lock
and how do i make sure that the sensor is working correctly
Old 06-17-2009, 02:13 PM
tozoM8's Avatar
You need to take the door panel off and you can get to the lock. There is a double micro switch bolted to the lock. One is for the lights and the other is for the alarm.
Old 06-18-2009, 08:20 AM
fkuk's Avatar
is there a page on the interet about this?
Quick Reply: interior lights pulse when passenger door is opened
