When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hi all
Can anyone help with the location of relay J105 (ABS return fliw pump) please, my Bentley seems to contradict itself and I have not been able to locate it visually.
Did you ever find the J105 relay for the return flow pump? The service manual says it is under the steering column, top right in the relay tray, #7 but it is vacant in my car.
I have an ongoing return flow pump error code even after pump replacement. It has to be wiring or the relay.
In the passenger side footwell there is a relay panel. Under all the carpets and behind a really cheap piece of hardboard. If you can stick your head in this location and look up as if you are trying to look behind the dash, then you may see the relay holder. The two relays on the right are for the ABS if I remember correctly.
I had a similar problem to you with an intermittent return pump fault. I actually bought a new pump but before fitting it I thought I'd try the relays. Swapped both relays for new ones and the problem is now fixed.
