Jacking and Supporting - mundane but critical
AudiWorld Uber User
How are you guys jacking and supporting your A8's when pulling your own maintenance? I've got the same issue with the A6 as well. I assume most of you don't have a serious 2- or 4-post frame lift.
I'd like to get all 4 corners in the air. I've got a good floor jack and jack stands. The problem is, if you jack the car using frame lift circles, you can't get a jack stand in there. If you lift at the trunk jack lift points, the frame lift circles are so close that you still can't get a jack stand in there.
My previous cars have generally had a center front and center rear lift point, where you could get the whole end up in the air, and then get jack stands under each side. I wish Audi had done something similar.
So what are you guys doing?
I can't say for sure, but maybe these jc whitney jack saddle gizzmos could provide some jack stand placement options.
HTH
Bill M
working on sig.
00 A8
95 S6 Avant
75 Carrera<ul><li><a href="http://www.jcwhitney.com/product.jhtml?CATID=4856&BQ=jcw2">jc whitney block gizzmos</a></li></ul>
HTH
Bill M
working on sig.
00 A8
95 S6 Avant
AudiWorld Uber User
Every time I see that banner ad on AudiWorld I mutter and lightly swear at J.C. Whitney.
I don't think I'll need them for the A8, but do think they'll help on the A6.
...after spending a long day wrestling with a cement grinder to get the floor real smooth. It wasnt a garage in its previous incarnation (it was the living room of the small house on our property), so the floor wasnt trowled out like it would have been if for a garage.
