keeps going into limp mode
So I have no idea what is going on with my 97 A8 Quattro. When I first start the car it isn't in limp mode, but when I put it in drive it doesn't feel like it goes into gear and when I push on the accelerator, as soon as it hits 1200rpm there is a small thud and it goes into limp mode. No matter how quickly or slowly I do this, as soon as it hits 1200rpm it does it. Everytime I turn the car off and back on it will no longer be in limp mode. It doesn't do it in reverse though. I can get the rpm's over 1200 in reverse and it's fine. I just got done replacing the Transmission Range Switch (F125) but I didn't clear the codes yet because I just haven't been able to get it done yet.Would clearing the codes matter? I'm thinking the next thing I'll do is replace the ATF fluid and filter and see what happens. I have no idea what to do after that though. Any help is appreciated.
These are the codes that were pulled awhile back before replacing the TRS:
Original Codes ECU
Sunday,23,September,2007,20:12:09:01947
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 4D0 907 557 D
Component and/or Version: 4.2L V8/4V MOTR AT D05
Software Coding: 01273
Work Shop Code: WSC 00214
9 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18098 - Malfunction Indication Light (K83): Electrical Malfunction
P1690 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 - -
Readiness: N/A
Original Codes TCM
Sunday,23,September,2007,20:13:33:01947
Address 02: Auto Trans
Control Module Part Number: 4D0 927 156 K
Component and/or Version: AG5 01L 4.2l4V USA D29
Software Coding: 00002
Work Shop Code: WSC 02314
5 Faults Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 35-10 - - - Intermittent
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
P0730 - 35-00 - -
P0730 - 35-00 - -
P0730 - 35-00 - -
18169 - Shift Lock Solenoid (N110): Short to Ground
P1761 - 35-10 - - - Intermittent
Recurring ECU Codes:
Sunday,23,September,2007,20:20:48:01947
Address 01: Engine
1 Fault Found:
P1690 - 35-00 - -
Readiness: N/A
Original Codes ECU
Address 01: Engine
9 Faults Found:
P1690 - 35-00 - -
P1136 - 35-00 - -
P1624 - 35-00 - -
Readiness: N/A
Original Codes TCM
5 Faults Found:
P0730 - 35-00 - -
P0730 - 35-00 - -
P0730 - 35-00 - -
Address 01: Engine
1 Fault Found:
P1690 - 35-00 - -
Readiness: N/A
Re: you blew your CLUTCH A Basket - Mine did the same thing...cost me a full rebuild - $4650
how sure are you of this? If this is the case I plan on parting the car out because the expense is not worth it for a car that is only worth $6000
Re: keeps going into limp mode
So how much could I get for my A8 with the tranny broken? It has 122k and everything is in fair shape. $2k maybe? I'm not going to pay to fix it because I was going to get rid of it right before this happened anyway. I need something with lower miles and cylinders. It was a nice car though...such a smooooth ride.
One more thing
If i get the car rolling and allow the rpms to rise above 1200rpm without stepping on the accelerator it doesn't go into limp mode. Then if I press on the accelerator after the rpms are over 1200rpm the tranny seems to just hunt and doesn't really engage, and then after about a minute of this it finally goes limp. Is this consistant with the broken clutch basket?
crivera82
Rocky Mountain Discussion
07-14-2011 12:17 PM
Angus Beef
19
02-16-2006 11:43 AM
