KEY FOB Battery
KEY FOB Battery
Hi, Can somebody tell me where the battery is in the key FOB? I pulled/slid the 2 sections of the FOB apart, but do not see where I need to pry to get to a battery. (This is my only key, so I'm a bit scared of killing it totally.) The half of the key with the the chain ring says a3/b5 on it, if that helps anybody.
Re: KEY FOB Battery
<center><img src="http://pictureposter.audiworld.com/128174/img_1292.t.jpg"></center><p>Just like mAgnum said. Just pull it apart with a screwdriver or similar. Then pull up the second door.
Good Luck!
Good Luck!
Re: KEY FOB Battery
<center><img src="http://pictureposter.audiworld.com/156752/dscf56461.jpg"></center><p>Just use your thumb and finger like this and pull apart and it will pop open and you will see the batteries.
Trebax
01-22-2013 10:02 AM
Ghant TMK
01-06-2003 12:25 PM
wnut
07-10-2002 02:54 PM
chuckleb
01-05-2001 09:05 PM
