Sponsored by:
Sponsored by:
Kickdown switch?
Old 11-01-2006, 07:10 PM
Nurburgringer's Avatar
Default Kickdown switch?
My kickdown switch doesn't seem to be working. Car doesn't downshift with full throttle in Tiptronic mode, and when in "D", it seems to downshift one gear too few.... Any easy places to look?
Old 11-01-2006, 09:02 PM
skiwi's Avatar
Default there is no switch
i suggest you adapt the throttle to ensure the travel is being measured correctly.
Old 11-01-2006, 09:07 PM
is that a VAG-COM function?
Old 11-01-2006, 11:01 PM
Always Overcharged's Avatar
Default I have a diagram of the switch from etka but my smtp server is down
I will try to email tommorro 3DO959897 is the part number
Old 11-01-2006, 11:02 PM
they call it an actuator-go figure
Old 11-02-2006, 12:41 AM
skiwi's Avatar
Default clarification
technically there is a switch, however it is integrated into the cable on most cars. later models with electronic throttle use the pedal stop for the switch.
you can also check the status using measuring block #8 of the tcm module.
Old 11-02-2006, 03:34 AM
dimitristx's Avatar
Default Won't downshift in Tip mode, any more than a manual would drop a gear when in 5th.
You need to kick the gear down manually when in Tip. For the standard "D" setting issues, you can reset the response (somewhat) via VAG-COM--seach the forum archives.
There was an article in a recent auto magazine I was reading about several new cars with throttle-by-wire having this same annoying lag issue when throttle is pressed, and it has been reasoned by various manufacturers that it helps with gas consumption. This could be enough of a reason why one may want to get a Lotus Elise/Exige :-)
Old 11-02-2006, 04:33 AM
ex-a8drifter's Avatar
Default There is a transmission code that allows that in A8s. Mine is set at 00011 and it kicks down in tip
if your pedal is down all the way. I know the code is not correct for S8s, but there has to be an equivalent code for S8s.
Old 11-02-2006, 04:34 AM
AudiWorld Uber User
JimR's Avatar
Yep.
Old 11-02-2006, 05:08 AM
Default Check this out
<ul><li><a href="https://forums.audiworld.com/a8/msgs/113097.phtml">https://forums.audiworld.com/a8/msgs/113097.phtml</a</li></ul>
Quick Reply: Kickdown switch?
