Labour time for camshaft tensioners on 40v 4.2 A8????
#11
It seems as though i could put that off as the alternator can be removed without pulling the front end off (i think).
Would i be good with this set of gaskets and this extra gasket for the coolant pipe job?
077-198-405
077-121-437
#13
I'm not sure this would apply to me because i have a D3 with the water cooled alternator. I might put a voltage regulator on as the cabin lights do flicker a little bit on first startup but has no issues charging battery and does not flicker anymore when warm. Battery is just over a year old.
077-198-405
077-121-437
077-198-405
077-121-437
As far as the alternator, I think the regulator/brushes come together as one bolt on part. Mine did and seems to be working fine.
#14
I don't want to bear that responsibility for correct gasket ordering. Lol! The 077-198-405 says it doesn't fit my 2001 D2, but maybe yours. I think I ordered that kit but the figure 8 gasket was wrong for mine so I gooped it up with some rtv and slapped it back in. I had the aluminum bufkin pipe that had 4 orings on it already. If you are ordering an OEM Audi plastic pipe I think the 077-121-437 rings are correct.
As for the pipe since Bufkin no longer sells any i bought this one ebay. Seems to have good reviews:
https://www.ebay.com/itm/253756606807
Unsure if i will just use the 4 orings already on it or put the Audi ones if they even fit. Did the stock OE plastic one only have 2?
#15
I think I've used that eBay pipe once with good results and have another sitting in the toolbox for the next timing belt job.
If it is the same one, the quality is excellent.
#16
#17
James Bufkin is selling the his oil cooler pipe at the moment.
Ebay search:![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I supported him as the originator of the lovely replacement piece. I think he should be preferred.
Ebay search:
Aluminum Oil Cooler "Bufkin Pipe"
People from the rest of the world, not USA and possibly Canada, will be confused by the peculiar spelling of aluminium![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
XBC01
12-10-2020 09:17 PM
XBC01
11-28-2020 11:10 AM
