Let the RNS-E Troubleshooting Begin
As I mentioned before, the RNS-E is installed, but the Nav portion cannot talk to the dash. I would have to guess it's because of the command language it is using over the CAN bus.
Dirk from the Nav Plus forum (who is a guru) happens to live in Chicago and came over yesterday to help me. He plugged into the infotainment CAN bus and logged some info with a tool he has.
I just ordered a better tool that he recommended, plug it into your PC, make a jumper from the CAN USB to your CAN bus and you can read the traffic:
<img src="http://www.easysync-ltd.com/contents/media/l_usb-can1.jpg">
I just need to hook up CAN high and CAN low, no power is required.....
<img src="http://www.easysync-ltd.com/contents/en-uk/gra20.gif">
Then you just tap into the CAN bus with insulation displacement connectors or whatever means. I actually have pigtails on my plug and play wiring harness that I can use.
Once I get this data, I will be able to use it to troubleshoot the implausible signal.
Then I will get a facelift A8/S8 with a factory Nav system and look at the traffic on it, and try to figure out what the differences are.
Once that is known, than maybe a work around solution can be made, such as a card or a CAN gate device which does the translations.
Here's what my dash looks now when I go from no navigation to an active route:
Normal:
<img src="http://www.audipages.com/upgrades/sm_DSC_4593.JPG">
Active Route:
<img src="http://www.audipages.com/upgrades/sm_DSC_4597.JPG">
Just in case you want to see what traffic looks like on the infotainment bus (READ: I'm screwed, I've got to learn what this means!):
la
ERROR!
READY>la
READY>
17:53:55.312 C0 653 3 02 02 18
17:53:55.334 C0 428 6 0F 01 00 00 00 00
17:53:55.344 R0 661 8 81 01 12 A0 00 00 00 00
17:53:55.352 C0 271 1 03
17:53:55.353 C0 625 5 9E C2 5D CD 39
17:53:55.362 C0 351 8 00 00 00 00 00 9B A5 00
17:53:55.374 R0 604 8 81 00 00 00 00 00 00 00
17:53:55.381 C0 621 3 00 FB 15
17:53:55.387 R0 42F 6 16 01 00 00 00 00
17:53:55.402 C0 635 3 14 00 1D
17:53:55.403 R0 6C0 1 A3
17:53:55.405 C0 6C1 2 A1 0F
17:53:55.433 R0 436 6 08 01 00 00 00 00
17:53:55.434 R0 6D0 1 A3
17:53:55.439 R0 6D1 6 A1 0F 8A FF 4A FF
17:53:55.450 C0 271 1 03
17:53:55.451 C0 625 5 78 BF 6A E3 39
17:53:55.462 C0 351 8 00 00 00 00 00 9B A5 00
17:53:55.482 C0 621 3 00 FB 15
17:53:55.483 C0 428 6 0F 01 00 00 00 00
17:53:55.503 R0 261 8 39 33 2E 31 00 20 20 20
17:53:55.505 R0 263 8 20 20 46 4D 2D 30 31 00
17:53:55.530 R0 42F 6 16 01 00 00 00 00
17:53:55.550 C0 271 1 03
17:53:55.551 C0 625 5 A8 5D 0E B4 39
17:53:55.562 C0 351 8 00 00 00 00 00 9B A5 00
17:53:55.572 C0 627 8 04 08 08 08 08 08 08 08
17:53:55.573 R0 436 6 08 01 00 00 00 00
17:53:55.582 C0 621 3 00 FB 15
17:53:55.600 C0 635 3 14 00 1D
17:53:55.620 C0 428 6 0F 01 00 00 00 00
17:53:55.650 C0 271 1 03
17:53:55.651 C0 625 5 4F 2E F3 A7 39
17:53:55.661 C0 351 8 00 00 00 00 00 9B A5 00
17:53:55.673 R0 42F 6 16 01 00 00 00 00
17:53:55.681 C0 621 3 00 FB 15
17:53:55.722 R0 436 6 08 01 00 00 00 00
17:53:55.749 C0 271 1 03
17:53:55.750 C0 625 5 76 F6 55 7A 39
17:53:55.751 C0 651 6 C0 16 21 00 11 40
17:53:55.760 C0 351 8 00 00 00 00 00 9B A5 00
17:53:55.770 C0 428 6 0F 01 00 00 00 00
17:53:55.780 C0 621 3 00 FB 15
17:53:55.791 C0 623 8 00 11 35 56 08 01 19 99
17:53:55.800 C0 635 3 14 00 1D
17:53:55.810 C0 653 3 02 02 18
17:53:55.816 R0 42F 6 16 01 00 00 00 00
17:53:55.838 R0 662 8 81 00 00 00 00 00 00 00
17:53:55.849 C0 271 1 03
17:53:55.850 C0 625 5 95 95 54 B5 39
17:53:55.860 C0 351 8 00 00 00 00 00 9B A5 00
17:53:55.862 R0 436 6 08 01 00 00 00 00
17:53:55.881 C0 621 3 00 FB 15
17:53:55.911 C0 428 6 0F 01 00 00 00 00
17:53:55.949 C0 271 1 03
17:53:55.950 C0 625 5 78 B5 2D 6F 39
17:53:55.958 R0 42F 6 16 01 00 00 00 00
17:53:55.961 C0 351 8 00 00 00 00 00 9B A5 00
17:53:55.979 C0 621 3 00 FB 15
17:53:56.000 C0 635 3 14 00 1D
17:53:56.001 R0 436 6 08 01 00 00 00 00
17:53:56.048 C0 271 1 03
17:53:56.049 C0 625 5 77 53 7F 23 39
17:53:56.050 C0 428 6 0F 01 00 00 00 00
17:53:56.058 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.069 C0 627 8 04 08 08 08 08 08 08 08
17:53:56.079 C0 621 3 00 FB 15
17:53:56.101 R0 42F 6 16 01 00 00 00 00
17:53:56.148 C0 271 1 03
17:53:56.149 C0 625 5 42 B2 C2 BA 39
17:53:56.151 R0 436 6 08 01 00 00 00 00
17:53:56.159 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.179 C0 621 3 00 FB 15
17:53:56.198 C0 635 3 14 00 1D
17:53:56.199 C0 428 6 0F 01 00 00 00 00
17:53:56.244 R0 42F 6 16 01 00 00 00 00
17:53:56.248 C0 271 1 03
17:53:56.248 C0 625 5 B1 03 93 EF 39
17:53:56.249 C0 651 6 C0 16 21 00 11 40
17:53:56.258 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.278 C0 621 3 00 FB 15
17:53:56.290 R0 436 6 08 01 00 00 00 00
17:53:56.300 R0 261 8 39 33 2E 31 00 20 20 20
17:53:56.301 R0 263 8 20 20 46 4D 2D 30 31 00
17:53:56.307 C0 653 3 02 02 18
17:53:56.338 C0 428 6 0F 01 00 00 00 00
17:53:56.347 C0 271 1 03
17:53:56.347 C0 625 5 A4 3F 55 88 39
17:53:56.350 R0 661 8 81 01 12 A0 00 00 00 00
17:53:56.357 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.378 C0 621 3 00 FB 15
17:53:56.380 R0 604 8 81 00 00 00 00 00 00 00
17:53:56.387 R0 42F 6 16 01 00 00 00 00
17:53:56.397 C0 635 3 15 00 1D
17:53:56.409 R0 6C0 1 A3
17:53:56.411 C0 6C1 2 A1 0F
17:53:56.429 R0 436 6 08 01 00 00 00 00
17:53:56.447 C0 271 1 03
17:53:56.447 C0 625 5 31 86 F4 2F 39
17:53:56.453 R0 6D0 1 A3
17:53:56.458 R0 6D1 6 A1 0F 8A FF 4A FF
17:53:56.459 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.477 C0 621 3 00 FB 15
17:53:56.478 C0 428 6 0F 01 00 00 00 00
17:53:56.530 R0 42F 6 16 01 00 00 00 00
17:53:56.547 C0 271 1 03
17:53:56.548 C0 625 5 A3 21 34 68 39
17:53:56.556 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.567 C0 627 8 04 08 08 08 08 08 08 08
17:53:56.577 C0 621 3 00 FB 15
17:53:56.579 R0 436 6 08 01 00 00 00 00
17:53:56.598 C0 635 3 15 00 1D
17:53:56.629 C0 428 6 0F 01 00 00 00 00
17:53:56.646 C0 271 1 03
17:53:56.647 C0 625 5 BC 7E 92 93 39
17:53:56.656 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.677 C0 621 3 00 FB 15
17:53:56.683 R0 42F 6 16 01 00 00 00 00
17:53:56.728 R0 436 6 08 01 00 00 00 00
17:53:56.746 C0 271 1 03
17:53:56.747 C0 625 5 74 9F 6F BD 39
17:53:56.748 C0 651 6 C0 16 21 00 11 40
17:53:56.756 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.778 C0 621 3 00 FB 15
17:53:56.779 C0 428 6 0F 01 00 00 00 00
17:53:56.786 C0 623 8 00 11 35 57 08 01 19 99
17:53:56.796 C0 635 3 15 00 1D
17:53:56.806 C0 653 3 02 02 18
17:53:56.825 R0 42F 6 16 01 00 00 00 00
17:53:56.847 C0 271 1 03
17:53:56.848 C0 625 5 96 F7 B0 37 39
17:53:56.855 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.868 R0 436 6 08 01 00 00 00 00
17:53:56.877 C0 621 3 00 FB 15
17:53:56.883 R0 662 8 81 00 00 00 00 00 00 00
17:53:56.916 C0 428 6 0F 01 00 00 00 00
17:53:56.944 C0 271 1 03
17:53:56.945 C0 625 5 22 E3 80 B6 39
17:53:56.956 C0 351 8 00 00 00 00 00 9B A5 00
17:53:56.968 R0 42F 6 16 01 00 00 00 00
17:53:56.976 C0 621 3 00 FB 15
17:53:56.995 C0 635 3 15 00 1E
17:53:57.017 R0 436 6 08 01 00 00 00 00
17:53:57.036 C0 627 8 05 08 08 08 08 08 08 08
17:53:57.044 C0 271 1 03
17:53:57.045 C0 625 5 FD 25 A1 F6 39
17:53:57.055 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.065 C0 627 8 04 08 08 08 08 08 08 08
17:53:57.066 C0 428 6 0F 01 00 00 00 00
17:53:57.075 C0 621 3 00 FB 15
17:53:57.097 R0 261 8 39 33 2E 31 00 20 20 20
17:53:57.098 R0 263 8 20 20 46 4D 2D 30 31 00
17:53:57.111 R0 42F 6 16 01 00 00 00 00
17:53:57.145 C0 271 1 03
17:53:57.146 C0 625 5 34 C2 AB D9 39
17:53:57.154 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.157 R0 436 6 08 01 00 00 00 00
17:53:57.175 C0 621 3 00 FB 15
17:53:57.194 C0 635 3 15 00 1E
17:53:57.205 C0 428 6 0F 01 00 00 00 00
17:53:57.243 C0 271 1 03
17:53:57.244 C0 625 5 B8 31 D7 56 39
17:53:57.245 C0 651 6 C0 16 21 00 11 40
17:53:57.254 R0 42F 6 16 01 00 00 00 00
17:53:57.254 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.276 C0 621 3 00 FB 15
17:53:57.296 R0 436 6 08 01 00 00 00 00
17:53:57.304 C0 653 3 02 02 18
17:53:57.334 C0 627 8 05 08 08 08 08 08 08 08
17:53:57.344 C0 271 1 03
17:53:57.345 C0 625 5 C0 0E AC 9C 39
17:53:57.346 C0 428 6 0F 01 00 00 00 00
17:53:57.347 R0 661 8 81 01 12 A0 00 00 00 00
17:53:57.354 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.363 C0 627 8 04 08 08 08 08 08 08 08
17:53:57.373 C0 621 3 00 FB 15
17:53:57.376 R0 604 8 81 00 00 00 00 00 00 00
17:53:57.393 C0 635 3 15 00 1E
17:53:57.397 R0 42F 6 16 01 00 00 00 00
17:53:57.405 R0 6C0 1 A3
17:53:57.407 C0 6C1 2 A1 0F
17:53:57.416 R0 261 8 39 33 2E 31 00 20 20 20
17:53:57.417 R0 263 8 20 20 46 4D 2D 30 31 00
17:53:57.445 C0 271 1 03
17:53:57.446 C0 625 5 F0 5F 7F BE 39
17:53:57.449 R0 436 6 08 01 00 00 00 00
17:53:57.453 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.456 R0 6D0 1 A3
17:53:57.458 R0 6D1 6 A1 0F 8A FF 4A FF
17:53:57.473 C0 621 3 00 FB 15
17:53:57.493 C0 428 6 0F 01 00 00 00 00
17:53:57.539 R0 42F 6 16 01 00 00 00 00
17:53:57.542 C0 271 1 03
17:53:57.543 C0 625 5 78 9C 37 CC 39
17:53:57.553 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.574 C0 621 3 00 FB 15
17:53:57.585 R0 436 6 08 01 00 00 00 00
17:53:57.593 C0 635 3 15 00 1E
17:53:57.633 C0 428 6 0F 01 00 00 00 00
17:53:57.642 C0 271 1 03
17:53:57.643 C0 625 5 78 0E 4B 5C 39
17:53:57.654 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.673 C0 621 3 00 FB 15
17:53:57.682 R0 42F 6 16 01 00 00 00 00
17:53:57.683 C0 627 8 05 08 08 08 08 08 08 08
17:53:57.724 R0 436 6 08 01 00 00 00 00
17:53:57.742 C0 271 1 03
17:53:57.743 C0 625 5 0C 72 10 88 39
17:53:57.744 C0 651 6 C0 16 21 00 11 40
17:53:57.752 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.763 C0 627 8 04 08 08 08 08 08 08 08
17:53:57.773 C0 621 3 00 FB 15
17:53:57.774 C0 428 6 0F 01 00 00 00 00
17:53:57.782 C0 623 8 00 11 35 58 08 01 19 99
17:53:57.792 C0 635 3 15 00 1E
17:53:57.802 C0 653 3 02 02 18
17:53:57.825 R0 42F 6 16 01 00 00 00 00
17:53:57.841 C0 271 1 03
17:53:57.842 C0 625 5 13 22 9D 0B 39
17:53:57.852 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.872 C0 621 3 00 FB 15
17:53:57.874 R0 436 6 08 01 00 00 00 00
17:53:57.923 C0 428 6 0F 01 00 00 00 00
17:53:57.930 R0 662 8 81 00 00 00 00 00 00 00
17:53:57.941 C0 271 1 03
17:53:57.942 C0 625 5 A8 9E B6 82 39
17:53:57.952 C0 351 8 00 00 00 00 00 9B A5 00
17:53:57.968 R0 42F 6 16 01 00 00 00 00
17:53:57.972 C0 621 3 00 FB 15
17:53:57.991 C0 635 3 15 00 1E
17:53:58.013 R0 436 6 08 01 00 00 00 00
17:53:58.031 C0 627 8 05 08 08 08 08 08 08 08
17:53:58.042 C0 271 1 03
17:53:58.042 C0 625 5 EB 0A DB FB 39
17:53:58.051 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.062 C0 627 8 04 08 08 08 08 08 08 08
17:53:58.063 C0 428 6 0F 01 00 00 00 00
17:53:58.072 C0 621 3 00 FB 15
17:53:58.111 R0 42F 6 16 01 00 00 00 00
17:53:58.140 C0 271 1 03
17:53:58.140 C0 625 5 63 93 A6 3F 39
17:53:58.151 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.153 R0 436 6 08 01 00 00 00 00
17:53:58.171 C0 621 3 00 FB 15
17:53:58.190 C0 635 3 15 00 1E
17:53:58.201 C0 428 6 0F 01 00 00 00 00
17:53:58.213 R0 261 8 39 33 2E 31 00 20 20 20
17:53:58.214 R0 263 8 20 20 46 4D 2D 30 31 00
17:53:58.240 C0 271 1 03
17:53:58.241 C0 625 5 E1 23 14 B9 39
17:53:58.242 C0 651 6 C0 16 21 00 11 40
17:53:58.253 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.254 R0 42F 6 16 01 00 00 00 00
17:53:58.270 C0 621 3 00 FB 15
17:53:58.299 C0 653 3 02 02 18
17:53:58.302 R0 436 6 08 01 00 00 00 00
17:53:58.331 C0 6C1 2 A3 00
17:53:58.340 C0 271 1 03
17:53:58.340 C0 625 5 C9 BD CF 17 39
17:53:58.342 R0 6C0 2 A1 0F
17:53:58.344 R0 661 8 81 01 12 A0 00 00 00 00
17:53:58.349 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.350 C0 428 6 0F 01 00 00 00 00
17:53:58.370 C0 621 3 00 FB 15
17:53:58.372 R0 604 8 81 00 00 00 00 00 00 00
17:53:58.390 C0 635 3 15 00 1E
17:53:58.396 R0 42F 6 16 01 00 00 00 00
17:53:58.438 C0 271 1 03
17:53:58.439 C0 625 5 86 6E 4D CC 39
17:53:58.443 R0 436 6 08 01 00 00 00 00
17:53:58.451 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.452 R0 6D0 1 A3
17:53:58.458 R0 6D1 6 A1 0F 8A FF 4A FF
17:53:58.468 C0 621 3 00 FB 15
17:53:58.489 C0 428 6 0F 01 00 00 00 00
17:53:58.538 C0 271 1 03
17:53:58.539 R0 42F 6 16 01 00 00 00 00
17:53:58.540 C0 625 5 90 84 34 FF 39
17:53:58.551 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.558 C0 627 8 04 08 08 08 08 08 08 08
17:53:58.569 C0 621 3 00 FB 15
17:53:58.581 R0 436 6 08 01 00 00 00 00
17:53:58.589 C0 635 3 15 00 1E
17:53:58.630 C0 428 6 0F 01 00 00 00 00
17:53:58.637 C0 271 1 03
17:53:58.638 C0 625 5 E2 11 15 2D 39
17:53:58.649 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.669 C0 621 3 00 FB 15
17:53:58.682 R0 42F 6 16 01 00 00 00 00
17:53:58.691 R0 261 8 39 33 2E 31 00 20 20 20
17:53:58.692 R0 263 8 20 20 46 4D 2D 30 31 00
17:53:58.730 R0 436 6 08 01 00 00 00 00
17:53:58.738 C0 271 1 03
17:53:58.739 C0 625 5 9A 3E F5 DE 39
17:53:58.740 C0 651 6 C0 16 21 00 11 40
17:53:58.748 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.767 C0 621 3 00 FB 15
17:53:58.778 C0 623 8 00 11 35 59 08 01 19 99
17:53:58.779 C0 428 6 0F 01 00 00 00 00
17:53:58.787 C0 635 3 15 00 1E
17:53:58.798 C0 653 3 02 02 18
17:53:58.825 R0 42F 6 16 01 00 00 00 00
17:53:58.837 C0 271 1 03
17:53:58.838 C0 625 5 6C 6B 03 5C 39
17:53:58.848 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.868 C0 621 3 00 FB 15
17:53:58.870 R0 436 6 08 01 00 00 00 00
17:53:58.920 C0 428 6 0F 01 00 00 00 00
17:53:58.936 C0 271 1 03
17:53:58.937 C0 625 5 4E F9 D3 CB 39
17:53:58.948 C0 351 8 00 00 00 00 00 9B A5 00
17:53:58.967 R0 42F 6 16 01 00 00 00 00
17:53:58.968 C0 621 3 00 FB 15
17:53:58.972 R0 662 8 81 00 00 00 00 00 00 00
17:53:58.986 C0 635 3 16 00 1E
17:53:59.009 R0 436 6 08 01 00 00 00 00
17:53:59.036 C0 271 1 03
17:53:59.037 C0 625 5 52 4A 55 3F 39
17:53:59.047 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.058 C0 627 8 04 08 08 08 08 08 08 08
17:53:59.059 C0 428 6 0F 01 00 00 00 00
17:53:59.068 C0 621 3 00 FB 15
17:53:59.110 R0 42F 6 16 01 00 00 00 00
17:53:59.136 C0 271 1 03
17:53:59.137 C0 625 5 D6 BD 70 DD 39
17:53:59.148 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.159 R0 436 6 08 01 00 00 00 00
17:53:59.167 C0 621 3 00 FB 15
17:53:59.186 C0 635 3 16 00 1E
17:53:59.207 C0 428 6 0F 01 00 00 00 00
17:53:59.235 C0 271 1 03
17:53:59.236 C0 625 5 D1 AB ED DE 39
17:53:59.237 C0 651 6 C0 16 21 00 11 40
17:53:59.246 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.253 R0 42F 6 16 01 00 00 00 00
17:53:59.267 C0 621 3 00 FB 15
17:53:59.296 C0 653 3 02 02 18
17:53:59.298 R0 436 6 08 01 00 00 00 00
17:53:59.335 C0 271 1 03
17:53:59.336 C0 625 5 DD 67 5E B9 39
17:53:59.338 R0 661 8 81 01 12 A0 00 00 00 00
17:53:59.347 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.348 C0 428 6 0F 01 00 00 00 00
17:53:59.366 C0 621 3 00 FB 15
17:53:59.368 R0 604 8 81 00 00 00 00 00 00 00
17:53:59.385 C0 635 3 16 00 1E
17:53:59.387 R0 6C0 1 A3
17:53:59.389 C0 6C1 2 A1 0F
17:53:59.396 R0 42F 6 16 01 00 00 00 00
17:53:59.435 C0 271 1 03
17:53:59.436 C0 625 5 72 A2 4E F7 39
17:53:59.439 R0 436 6 08 01 00 00 00 00
17:53:59.445 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.448 R0 6D0 1 A3
17:53:59.457 R0 6D1 6 A1 0F 8A FF 4A FF
17:53:59.465 C0 621 3 00 FB 15
17:53:59.487 C0 428 6 0F 01 00 00 00 00
17:53:59.488 R0 261 8 39 33 2E 31 00 20 20 20
17:53:59.489 R0 263 8 20 20 46 4D 2D 30 31 00
17:53:59.534 C0 271 1 03
17:53:59.535 C0 625 5 1B F9 CE 7F 39
17:53:59.538 R0 42F 6 16 01 00 00 00 00
17:53:59.545 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.555 C0 627 8 04 08 08 08 08 08 08 08
17:53:59.566 C0 621 3 00 FB 15
17:53:59.584 C0 635 3 16 00 1E
17:53:59.587 R0 436 6 08 01 00 00 00 00
17:53:59.635 C0 271 1 03
17:53:59.636 C0 625 5 47 DF 7B 7F 39
17:53:59.637 C0 428 6 0F 01 00 00 00 00
17:53:59.645 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.665 C0 621 3 00 FB 15
17:53:59.681 R0 42F 6 16 01 00 00 00 00
17:53:59.726 R0 436 6 08 01 00 00 00 00
17:53:59.734 C0 271 1 03
17:53:59.735 C0 625 5 E3 A8 4A 99 39
17:53:59.736 C0 651 6 C0 16 21 00 11 40
17:53:59.744 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.765 C0 621 3 00 FB 15
17:53:59.775 C0 623 8 00 11 36 00 08 01 19 99
17:53:59.776 C0 428 6 0F 01 00 00 00 00
17:53:59.785 C0 635 3 16 00 1E
17:53:59.793 C0 653 3 02 02 18
17:53:59.824 R0 42F 6 16 01 00 00 00 00
17:53:59.833 C0 271 1 03
17:53:59.834 C0 625 5 94 26 98 F6 39
17:53:59.844 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.864 C0 621 3 00 FB 15
17:53:59.866 R0 436 6 08 01 00 00 00 00
17:53:59.914 C0 428 6 0F 01 00 00 00 00
17:53:59.933 C0 271 1 03
17:53:59.934 C0 625 5 44 95 9E 6C 39
17:53:59.945 C0 351 8 00 00 00 00 00 9B A5 00
17:53:59.964 C0 621 3 00 FB 15
17:53:59.967 R0 42F 6 16 01 00 00 00 00
17:53:59.983 C0 635 3 16 00 1E
17:54:00.015 R0 436 6 08 01 00 00 00 00
17:54:00.016 R0 662 8 81 00 00 00 00 00 00 00
17:54:00.034 C0 271 1 03
17:54:00.035 C0 625 5 6C A1 1C 45 39
17:54:00.043 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.053 C0 627 8 04 08 08 08 08 08 08 08
17:54:00.063 C0 621 3 00 FB 15
17:54:00.064 C0 428 6 0F 01 00 00 00 00
17:54:00.110 R0 42F 6 16 01 00 00 00 00
17:54:00.125 R0 261 8 39 33 2E 31 00 20 20 20
17:54:00.126 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:00.132 C0 271 1 03
17:54:00.133 C0 625 5 B1 32 87 67 39
17:54:00.142 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.155 R0 436 6 08 01 00 00 00 00
17:54:00.164 C0 621 3 00 FB 15
17:54:00.182 C0 635 3 16 00 1E
17:54:00.204 C0 428 6 0F 01 00 00 00 00
17:54:00.233 C0 271 1 03
17:54:00.234 C0 625 5 07 3E 7E 76 39
17:54:00.235 C0 651 6 C0 16 21 00 11 40
17:54:00.242 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.252 R0 42F 6 16 01 00 00 00 00
17:54:00.263 C0 621 3 00 FB 15
17:54:00.292 C0 653 3 02 02 18
17:54:00.295 R0 436 6 08 01 00 00 00 00
17:54:00.333 C0 271 1 03
17:54:00.333 C0 625 5 5A BA 30 31 39
17:54:00.334 R0 661 8 81 01 12 A0 00 00 00 00
17:54:00.342 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.343 C0 428 6 0F 01 00 00 00 00
17:54:00.362 C0 621 3 00 FB 15
17:54:00.364 R0 604 8 81 00 00 00 00 00 00 00
17:54:00.381 C0 635 3 16 00 1E
17:54:00.383 R0 6C0 1 A3
17:54:00.385 C0 6C1 2 A1 0F
17:54:00.395 R0 42F 6 16 01 00 00 00 00
17:54:00.430 C0 271 1 03
17:54:00.431 C0 625 5 EB 0A 36 47 39
17:54:00.442 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.443 R0 436 6 08 01 00 00 00 00
17:54:00.453 R0 6D0 1 A3
17:54:00.456 R0 6D1 6 A1 0F 8A FF 4A FF
17:54:00.463 C0 621 3 00 FB 15
17:54:00.491 C0 428 6 0F 01 00 00 00 00
17:54:00.531 C0 271 1 03
17:54:00.532 C0 625 5 A1 B1 2B 37 39
17:54:00.538 R0 42F 6 16 01 00 00 00 00
17:54:00.543 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.551 C0 627 8 04 08 08 08 08 08 08 08
17:54:00.561 C0 621 3 00 FB 15
17:54:00.581 C0 635 3 16 00 1E
17:54:00.583 R0 436 6 08 01 00 00 00 00
17:54:00.630 C0 271 1 03
17:54:00.631 C0 625 5 C3 B2 46 60 39
17:54:00.632 C0 428 6 0F 01 00 00 00 00
17:54:00.640 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.661 C0 621 3 00 FB 15
17:54:00.681 R0 42F 6 16 01 00 00 00 00
17:54:00.722 R0 436 6 08 01 00 00 00 00
17:54:00.729 C0 271 1 03
17:54:00.730 C0 625 5 A3 50 C8 C8 39
17:54:00.731 C0 651 6 C0 16 21 00 11 40
17:54:00.742 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.762 C0 621 3 00 FB 15
17:54:00.771 C0 623 8 00 11 36 01 08 01 19 99
17:54:00.772 C0 428 6 0F 01 00 00 00 00
17:54:00.780 C0 635 3 16 00 1E
17:54:00.791 C0 653 3 02 02 18
17:54:00.824 R0 42F 6 16 01 00 00 00 00
17:54:00.829 C0 271 1 03
17:54:00.830 C0 625 5 5E 24 22 FE 39
17:54:00.841 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.860 C0 621 3 00 FB 15
17:54:00.872 R0 436 6 08 01 00 00 00 00
17:54:00.920 C0 428 6 0F 01 00 00 00 00
17:54:00.924 R0 261 8 39 33 2E 31 00 20 20 20
17:54:00.925 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:00.929 C0 271 1 03
17:54:00.930 C0 625 5 A6 4E E5 33 39
17:54:00.939 C0 351 8 00 00 00 00 00 9B A5 00
17:54:00.960 C0 621 3 00 FB 15
17:54:00.966 R0 42F 6 16 01 00 00 00 00
17:54:00.979 C0 635 3 16 00 1E
17:54:01.011 R0 436 6 08 01 00 00 00 00
17:54:01.029 C0 271 1 03
17:54:01.030 C0 625 5 34 16 FD D2 39
17:54:01.039 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.050 C0 627 8 04 08 08 08 08 08 08 08
17:54:01.060 R0 662 8 81 00 00 00 00 00 00 00
17:54:01.061 C0 621 3 00 FB 15
17:54:01.062 C0 428 6 0F 01 00 00 00 00
17:54:01.109 R0 42F 6 16 01 00 00 00 00
17:54:01.128 C0 271 1 03
17:54:01.129 C0 625 5 AB A5 67 12 39
17:54:01.139 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.151 R0 436 6 08 01 00 00 00 00
17:54:01.159 C0 621 3 00 FB 15
17:54:01.178 C0 635 3 16 00 1E
17:54:01.199 C0 428 6 0F 01 00 00 00 00
17:54:01.228 C0 271 1 03
17:54:01.229 C0 625 5 14 6A 9D 24 39
17:54:01.230 C0 651 6 C0 16 21 00 11 40
17:54:01.238 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.252 R0 42F 6 16 01 00 00 00 00
17:54:01.259 C0 621 3 00 FB 15
17:54:01.288 C0 653 3 02 02 18
17:54:01.300 R0 436 6 08 01 00 00 00 00
17:54:01.327 C0 271 1 03
17:54:01.328 C0 625 5 55 87 B4 9D 39
17:54:01.331 R0 661 8 81 01 12 A0 00 00 00 00
17:54:01.338 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.349 C0 428 6 0F 01 00 00 00 00
17:54:01.358 C0 621 3 00 FB 15
17:54:01.360 R0 604 8 81 00 00 00 00 00 00 00
17:54:01.377 C0 635 3 16 00 1E
17:54:01.379 R0 6C0 1 A3
17:54:01.381 C0 6C1 2 A1 0F
17:54:01.395 R0 42F 6 16 01 00 00 00 00
17:54:01.427 C0 271 1 03
17:54:01.428 C0 625 5 7B 07 4D 7F 39
17:54:01.439 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.440 R0 436 6 08 01 00 00 00 00
17:54:01.449 R0 6D0 1 A3
17:54:01.456 R0 6D1 6 A1 0F 8A FF 4A FF
17:54:01.458 C0 621 3 00 FB 15
17:54:01.487 C0 428 6 0F 01 00 00 00 00
17:54:01.527 C0 271 1 03
17:54:01.528 C0 625 5 BE D4 B7 6B 39
17:54:01.537 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.538 R0 42F 6 16 01 00 00 00 00
17:54:01.547 C0 627 8 04 08 08 08 08 08 08 08
17:54:01.558 C0 621 3 00 FB 15
17:54:01.577 C0 635 3 16 00 1E
17:54:01.579 R0 436 6 08 01 00 00 00 00
17:54:01.626 C0 271 1 03
17:54:01.627 C0 625 5 39 7C 54 8E 39
17:54:01.628 C0 428 6 0F 01 00 00 00 00
17:54:01.638 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.655 C0 621 3 00 FB 15
17:54:01.680 R0 42F 6 16 01 00 00 00 00
17:54:01.718 R0 261 8 39 33 2E 31 00 20 20 20
17:54:01.720 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:01.726 C0 271 1 03
17:54:01.727 C0 625 5 FB 67 77 D1 39
17:54:01.728 C0 651 6 C0 16 21 00 11 40
17:54:01.729 R0 436 6 08 01 00 00 00 00
17:54:01.737 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.757 C0 621 3 00 FB 15
17:54:01.766 C0 623 8 00 11 36 02 08 01 19 99
17:54:01.777 C0 635 3 17 00 1E
17:54:01.778 C0 428 6 0F 01 00 00 00 00
17:54:01.785 C0 653 3 02 02 18
17:54:01.823 R0 42F 6 16 01 00 00 00 00
17:54:01.825 C0 271 1 03
17:54:01.826 C0 625 5 9F 57 DE 33 39
17:54:01.837 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.856 C0 621 3 00 FB 15
17:54:01.868 R0 436 6 08 01 00 00 00 00
17:54:01.869 R0 261 8 39 33 2E 31 00 20 20 20
17:54:01.870 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:01.916 C0 428 6 0F 01 00 00 00 00
17:54:01.925 C0 271 1 03
17:54:01.926 C0 625 5 56 A4 92 59 39
17:54:01.937 C0 351 8 00 00 00 00 00 9B A5 00
17:54:01.956 C0 621 3 00 FB 15
17:54:01.966 R0 42F 6 16 01 00 00 00 00
17:54:01.975 C0 635 3 17 00 1F
17:54:02.007 R0 436 6 08 01 00 00 00 00
17:54:02.015 C0 627 8 05 08 08 08 08 08 08 08
17:54:02.025 C0 271 1 03
17:54:02.026 C0 625 5 DB 39 12 4D 39
17:54:02.036 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.045 C0 627 8 04 08 08 08 08 08 08 08
17:54:02.056 C0 621 3 00 FB 15
17:54:02.057 C0 428 6 0F 01 00 00 00 00
17:54:02.105 R0 662 8 81 00 00 00 00 00 00 00
17:54:02.109 R0 42F 6 16 01 00 00 00 00
17:54:02.124 C0 271 1 03
17:54:02.125 C0 625 5 17 1E E9 9E 39
17:54:02.135 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.155 C0 621 3 00 FB 15
17:54:02.157 R0 436 6 08 01 00 00 00 00
17:54:02.175 C0 635 3 17 00 1F
17:54:02.207 C0 428 6 0F 01 00 00 00 00
17:54:02.224 C0 271 1 03
17:54:02.225 C0 625 5 FA 19 6F 9E 39
17:54:02.226 C0 651 6 C0 16 21 00 11 40
17:54:02.234 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.251 R0 42F 6 16 01 00 00 00 00
17:54:02.254 C0 621 3 00 FB 15
17:54:02.285 C0 653 3 02 02 18
17:54:02.296 R0 436 6 08 01 00 00 00 00
17:54:02.314 C0 627 8 05 08 08 08 08 08 08 08
17:54:02.323 C0 271 1 03
17:54:02.324 C0 625 5 E8 C5 47 36 39
17:54:02.326 R0 661 8 81 01 12 A0 00 00 00 00
17:54:02.335 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.344 C0 627 8 04 08 08 08 08 08 08 08
17:54:02.345 C0 428 6 0F 01 00 00 00 00
17:54:02.354 C0 621 3 00 FB 15
17:54:02.356 R0 604 8 81 00 00 00 00 00 00 00
17:54:02.374 C0 635 3 17 00 1F
17:54:02.375 R0 6C0 1 A3
17:54:02.377 C0 6C1 2 A1 0F
17:54:02.394 R0 42F 6 16 01 00 00 00 00
17:54:02.423 C0 271 1 03
17:54:02.424 C0 625 5 32 63 05 A0 39
17:54:02.433 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.437 R0 436 6 08 01 00 00 00 00
17:54:02.445 R0 6D0 1 A3
17:54:02.454 C0 621 3 00 FB 15
17:54:02.456 R0 6D1 6 A1 0F 8A FF 4A FF
17:54:02.485 C0 428 6 0F 01 00 00 00 00
17:54:02.523 C0 271 1 03
17:54:02.524 C0 625 5 FE F5 20 1D 39
17:54:02.534 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.538 R0 42F 6 16 01 00 00 00 00
17:54:02.553 C0 621 3 00 FB 15
17:54:02.573 C0 635 3 17 00 1F
17:54:02.585 R0 436 6 08 01 00 00 00 00
17:54:02.623 C0 271 1 03
17:54:02.624 C0 625 5 0E 87 2D BA 39
17:54:02.632 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.633 C0 428 6 0F 01 00 00 00 00
17:54:02.653 C0 621 3 00 FB 15
17:54:02.663 C0 627 8 05 08 08 08 08 08 08 08
17:54:02.665 R0 261 8 39 33 2E 31 00 20 20 20
17:54:02.666 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:02.680 R0 42F 6 16 01 00 00 00 00
17:54:02.721 C0 271 1 03
17:54:02.722 C0 625 5 0E A0 0F 76 39
17:54:02.723 C0 651 6 C0 16 21 00 11 40
17:54:02.725 R0 436 6 08 01 00 00 00 00
17:54:02.732 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.743 C0 627 8 04 08 08 08 08 08 08 08
17:54:02.753 C0 621 3 00 FB 15
17:54:02.762 C0 623 8 00 11 36 03 08 01 19 99l
17:54:02.772 C0 635 3 17 00 1F
17:54:02.773 C0 428 6 0F 01 00 00 00 00
17:54:02.783 C0 653 3 02 02 18
17:54:02.822 C0 271 1 03
17:54:02.823 R0 42F 6 16 01 00 00 00 00
17:54:02.823 C0 625 5 C4 34 4E 11 39
17:54:02.832 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.852 C0 621 3 00 FB 15
17:54:02.864 R0 436 6 08 01 00 00 00 00
17:54:02.913 C0 428 6 0F 01 00 00 00 00
17:54:02.921 C0 271 1 03
17:54:02.922 C0 625 5 78 A8 26 49 39
17:54:02.931 C0 351 8 00 00 00 00 00 9B A5 00
17:54:02.952 C0 621 3 00 FB 15
17:54:02.965 R0 42F 6 16 01 00 00 00 00
17:54:02.972 C0 635 3 17 00 1F
17:54:03.012 C0 627 8 05 08 08 08 08 08 08 08
17:54:03.013 R0 436 6 08 01 00 00 00 00
17:54:03.020 C0 271 1 03
17:54:03.021 C0 625 5 E0 69 2C 19 39
17:54:03.031 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.041 C0 627 8 04 08 08 08 08 08 08 08
17:54:03.052 C0 621 3 00 FB 15
17:54:03.061 C0 428 6 0F 01 00 00 00 00
17:54:03.108 R0 42F 6 16 01 00 00 00 00
17:54:03.120 C0 271 1 03
17:54:03.121 C0 625 5 EA 53 6A 45 39
17:54:03.132 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.150 R0 662 8 81 00 00 00 00 00 00 00
17:54:03.151 C0 621 3 00 FB 15
17:54:03.153 R0 436 6 08 01 00 00 00 00
17:54:03.171 C0 635 3 17 00 1F
17:54:03.202 C0 428 6 0F 01 00 00 00 00
17:54:03.221 C0 271 1 03
17:54:03.222 C0 625 5 C3 8A 6B 19 39
17:54:03.223 C0 651 6 C0 16 21 00 11 40
17:54:03.230 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.251 R0 42F 6 16 01 00 00 00 00
17:54:03.252 C0 621 3 00 FB 15
17:54:03.280 C0 653 3 02 02 18
17:54:03.302 R0 436 6 08 01 00 00 00 00
17:54:03.310 C0 6C1 2 A3 00
17:54:03.319 C0 271 1 03
17:54:03.320 C0 625 5 DD DE 1B 0D 39
17:54:03.322 R0 6C0 2 A1 0F
17:54:03.323 R0 261 8 39 33 2E 31 00 20 20 20
17:54:03.324 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:03.326 R0 661 8 81 01 12 A0 00 00 00 00
17:54:03.330 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.350 C0 621 3 00 FB 15
17:54:03.351 C0 428 6 0F 01 00 00 00 00
17:54:03.352 R0 604 8 81 00 00 00 00 00 00 00
17:54:03.370 C0 635 3 17 00 1F
17:54:03.404 R0 42F 6 16 01 00 00 00 00
17:54:03.419 C0 271 1 03
17:54:03.420 C0 625 5 EB AA 54 33 39
17:54:03.430 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.449 C0 621 3 00 FB 15
17:54:03.452 R0 436 6 08 01 00 00 00 00
17:54:03.453 R0 6D0 1 A3
17:54:03.455 R0 6D1 6 A1 0F 8A FF 4A FF
17:54:03.502 C0 428 6 0F 01 00 00 00 00
17:54:03.519 C0 271 1 03
17:54:03.520 C0 625 5 01 35 AA C3 39
17:54:03.522 R0 261 8 39 33 2E 31 00 20 20 20
17:54:03.523 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:03.529 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.540 C0 627 8 04 08 08 08 08 08 08 08
17:54:03.547 R0 42F 6 16 01 00 00 00 00
17:54:03.550 C0 621 3 00 FB 15
17:54:03.569 C0 635 3 17 00 1F
17:54:03.591 R0 436 6 08 01 00 00 00 00
17:54:03.619 C0 271 1 03
17:54:03.619 C0 625 5 47 74 AB B5 39
17:54:03.630 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.640 C0 428 6 0F 01 00 00 00 00
17:54:03.650 C0 621 3 00 FB 15
17:54:03.690 R0 42F 6 16 01 00 00 00 00
17:54:03.718 C0 271 1 03
17:54:03.719 C0 625 5 B1 BC A7 93 39
17:54:03.720 C0 651 6 C0 16 21 00 11 40
17:54:03.729 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.740 R0 436 6 08 01 00 00 00 00
17:54:03.749 C0 621 3 00 FB 15
17:54:03.758 C0 623 8 00 11 36 04 08 01 19 99
17:54:03.769 C0 635 3 17 00 1F
17:54:03.779 C0 653 3 02 02 18
17:54:03.788 C0 428 6 0F 01 00 00 00 00
17:54:03.818 C0 271 1 03
17:54:03.819 C0 625 5 6E 81 84 04 39
17:54:03.828 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.832 R0 42F 6 16 01 00 00 00 00
17:54:03.848 C0 621 3 00 FB 15
17:54:03.880 R0 436 6 08 01 00 00 00 00
17:54:03.917 C0 271 1 03
17:54:03.918 C0 625 5 F1 D1 16 9F 39
17:54:03.927 C0 351 8 00 00 00 00 00 9B A5 00
17:54:03.928 C0 428 6 0F 01 00 00 00 00
17:54:03.948 C0 621 3 00 FB 15
17:54:03.967 C0 635 3 17 00 1F
17:54:03.975 R0 42F 6 16 01 00 00 00 00
17:54:04.016 C0 271 1 03
17:54:04.017 C0 625 5 AF A9 7F 26 39
17:54:04.019 R0 436 6 08 01 00 00 00 00
17:54:04.027 C0 351 8 00 00 00 00 00 9B A5 00
17:54:04.037 C0 627 8 04 08 08 08 08 08 08 08
17:54:04.047 C0 621 3 00 FB 15
17:54:04.067 C0 428 6 0F 01 00 00 00 00
17:54:04.117 C0 271 1 03
17:54:04.118 C0 625 5 59 BD 78 EB 39
17:54:04.119 R0 42F 6 16 01 00 00 00 00
17:54:04.126 C0 351 8 00 00 00 00 00 9B A5 00
17:54:04.147 C0 621 3 00 FB 15
17:54:04.166 C0 635 3 17 00 1F
17:54:04.169 R0 436 6 08 01 00 00 00 00
17:54:04.194 R0 662 8 81 00 00 00 00 00 00 00
17:54:04.215 C0 271 1 03
17:54:04.216 C0 625 5 DF 16 4F 64 39
17:54:04.217 C0 651 6 C0 16 21 00 11 40
17:54:04.218 C0 428 6 0F 01 00 00 00 00
17:54:04.226 C0 351 8 00 00 00 00 00 9B A5 00
17:54:04.248 C0 621 3 00 FB 15
17:54:04.271 R0 42F 6 16 01 00 00 00 00
17:54:04.277 C0 653 3 02 02 18
17:54:04.316 C0 271 1 03
17:54:04.316 C0 625 5 69 8D 2A CA 39
17:54:04.318 R0 436 6 08 01 00 00 00 00
17:54:04.319 R0 261 8 39 33 2E 31 00 20 20 20
17:54:04.320 R0 263 8 20 20 46 4D 2D 30 31 00
17:54:04.322 R0 661 8 81 01 12 A0 00 00 00 00
17:54:04.327 C0 351 8 00 00 00 00 00 9B A5 00
17:54:04.346 C0 621 3 00 FB 15
17:54:04.348 R0 604 8 81 00 00 00 00 00 00 00
17:54:04.366 C0 635 3 17 00 1F
17:54:04.367 C0 428 6 0F 01 00 00 00 00
17:54:04.368 R0 6C0 1 A3
17:54:04.370 C0 6C1 2 A1 0F
17:54:04.414 R0 42F 6 16 01 00 00 00 00
17:54:04.416 C0 271 1 03
17:54:04.417 C0 625 5 3B 8F B3 A5 39
17:54:04.425 C0 351 8 00 00 00 00 00 9B A5 00
17:54:04.446 C0 621 3 00 FB 15
17:54:04.447 R0 6D0 1 A3
17:54:04.455 R0 6D1 6 A1 0F 8A FF 4A FF
17:54:04.467 R0 436 6 08 01 00 00 00 00
17:54:04.515 C0 271 1 03
17:54:04.515 C0 625 5 72 A2 F1 9B 39
17:54:04.516 C0 428 6 0F 01 00 00 00 00
17:54:04.527 C0 351 8 00 00 00 00 00 9B A5 00
17:54:04.535 C0 627 8 04 08 08 08 08 08 08 08
17:54:04.546 C0 621 3 00 FB 15
17:54:04.565 C0 635 3 17 00 1F
17:54:04.567 R0 42F 6 16 01 00 00 00 00
17:54:04.615 C0 271 1 03
17:54:04.616 C0 625 5 CE EB 0E 35 39
17:54:04.617 R0 436 6 08 01 00 00 00 00
17:54:04.625 C0 351 8 00 00 00 00 00 9B A5 00
17:54:04.645 C0 621 3 00 FB 15
READY>
Normal:
Active Route:
la
ERROR!
READY>la
READY>
READY>
Re: Let the RNS-E Troubleshooting Begin
I suppose this is completely obvious to everyone else. but the numbers at the left are a time stamp, military time, Hours: minutes: seconds: thousandths
So what is the significance of the "CO" and the "RO" Do they identify components or outbound and inbound commands? or commands and responses?
A couple of lines repeat over and over with no change, like:
C0 271 1 03
or
or
C0 621 3 00 FB 15
others vary. After a bit it seems to settle in to a series 8 lines over and over...see the CO 271 line, it repeats every 8 lines after a while. Do the three characters after the CO or RO specifiy a command and then the rest parameters?
Do keep us advised, and good luck!
C0 271 1 03
or
or
C0 621 3 00 FB 15
The number such as 271, 351 or 621 are command lines (excuse me, I don't really know what to call them)....
261 and 263 are from radio/navi to the DIS, (line one in the display is 261, line two in the display is 263), 271 is the ignition switch signal.....for example:
271 (ignition switch command) 1 (size of command) 03 (key position, it was on, but the engine wasn't started)
If the command had more than a size of one, such as 3, 6 or 8, that would be the second number, then the string after that would be the actual command.
The DIS to Navigation is command line 6Cx and it is a complex message/response conversation. I'm really not that smart, I'm just re writing what Dirk wrote on the nav plus forum.
He gave me a spreadsheet with some of these things in it.
So what you do:
1. Log data with a terminal tool
2. Paste in Excel and filter data for the modules you want to look at.
3. Review filtered data if you can make heads or toes out of it.
I can't say I really want to learn about this, but in the end it could be pretty interesting. It will be interesting to see if I will be able to pick anything up by reviewing the data.
So what you do:
PaulW, it looks like you get to learn a new language!
Monstrous task you're undertaking, big buddy, and we've all seen just how determined you can be. It's only a matter of time before you get 'er licked.
Looks like HEX with like command/reply statements. My suggestion - Talk to Uwe Ross over at Ross Tech or Jeff at Rocketchip. APR programmers might be able to help you out too...
Willing to Help Out
Hi Paul,
I just got myself an 01 S8 which has the original Sat Nav System. I am just acquiring all the parts to install an RNS-E.
I am willing to help out in figuring out the DIS problem. I am vary familiar with J1939 communications which is the Commercial truck version of CAN. The Audi messages are totally different but I have quite a few tools to log the info so I may be able to decode it.
I then may be able to design a gateway to translate the RNS-E messages using some of the products I develop (we make Tire Pressure Monitoring Systems).
Shawn
Shawn
CAN Format
Can messages start with an 11bit or 29 bit identifier. These messages have an 11bit identifier so they must be using CAN A. (None of the first numbers are greater the 7FF).
The next byte just indicates how many data bytes follow. There can only be 8 data bytes max.
The first byte in that sequence must indicate the control codes. The could be R0 for Remote frames, C0, not sure maybe just local.
What the identifiers mean and the data that follows is proprietary. If anyone has specs on these I would be sure love to get my hands on them
Shawn
Shawn
