Like a punch in the gut! The A8 dies in traffic...
#12
My local shop took an initial look at the car and said that with the sending units disconnected, it says (on diag tool?) 6 liters and with the sending units connected it says 12 liters. Calibration issue?
My big concern is that I filled the tank and only got ~275 miles out of it before it died. IF it is really out of fuel, where did the fuel go? I know there was a LITTLE bit (that smelled awful) on the garage floor the first night, but not much after that. Are there lines that could be hemorrhaging fuel ONLY while the car is running? The gas cap was 1/2 tight, but you wouldn't lose THAT much to vapor, would you? And without smell in the garage.
IF putting fuel back in the tank lets it run AND I can get it hooked up to (borrowed) VAG-COM, what measuring or diagnostic tools should I use?
#18
As we've discussed, I do most of the driving in my S8 in "4", which is comparable to "3" in an A8. I haven't reset the "avg mpg" of my instrument cluster for the last three full tanks of gas. It's showing 17 mpg, but to get almost anywhere I have to jump on an Interstate (where I still usually use "4").
