Loud noise from cooling fan 2001 A8L
#11
If you want to know exactly how hot your A8 is running ...
Press and hold the recirc button, and then press the vent control up arrow. The left temp indicator then displays a code number, and the right temp indicator it's value. Page up thru the codes with the temp + button until the left indicator reads 102. The right indicator then is coolant temp in oC as read by the instrument cluster. If there's no problems, 99.9% of the time the temperature should stabilize between 87 and 95 oC. When you shut off and restart the car, the HVAC controls will return to normal function.<ul><li><a href="https://forums.audiworld.com/a8/msgs/93452.phtml">Digital dash codes</a></li></ul>
#13
My thought is that you should post this in the A8 D3 section as that's what you own. Beyond that I would ask what you are talking about as what you're saying makes no sense. Why would a manual or automatic sound any different? Confusing.
#14
allroadCole
05-12-2008 07:45 AM
javanator
12
05-22-2007 08:55 AM
Polar
09-02-2004 07:27 PM
