Major service interval - engine cleanout
I am due for a regular major engine service on my '98 A8 at 96,000 km (approx. 60,000 mi). In addition to the usual major tuneup stuff, the dealer is recommending that I get the engine cleaned of carbon and other deposits through a procedure in which they burn a different type of fuel through the system. This is not called for by Audi in the service manual, but it is something the dealer recommends. Of course, it also adds approx. 60% additional cost to the already big dollar for the major service.
Has anyone ever had this done, or can you offer any insight into the value of the procedure? My current thinking is, if Audi don't call for it, I'll pass, but if it is deemed by people in this forum to be of real value, I'll reconsider.
...but some questions you should ask:
1- What is the value of doing this? Does it improve performance or mileage? Has there been evidence that it prevents issues down the road?
2- If you maintain your car according to schedule, is it necessary?
3- Any other customers/referrals they could give you?
Are you in the U.S.? I am assuming you are not, since you stated your mileage in "km"- is there some regulatory "logic" behind their recommendation (emissions)?
In almost all cases, this is an absolutely unnecessary procedure. It may cause more harm than good.
I would think twice about using this particular repair shop or dealer. They may try to sell you atomic polymer paint sealant and bionic fabric guard as well.
Sometimes, on older cars m(eg, small 6 cyl BMW's with K and L Jetronic), intake valve stems and injector nozzles can get shrouded with carbon. Inexpensive Chevron Techtron additive is the best treatment for this.
Pouring Diesel fuel through a running gas engine, or flushing out the crankcase with solvent are things that old shops may still do to old cars, based primarily on old wives' tales. Don't let 'em do it to yours. Use Audi recommended oils, lubes, parts, and procedures only.
Hope this helps
I have not heard of this being a problem on Late model Audi's
Hope this helps
BG 44 under pressure, gas tank the whole stuff was 160 including throttle body cleaning. Why so much more for an A8 (I have an A4 2.8)
Thanks for the comments.
Re the question about my location, I live in Canada. The dealer is not talking about regulatory issues - the recommendation is strictly made on the basis of the presumed benefits of the so-called cleaning.
Re the cost issue, I'm assuming your $160 cost is USD. The estimate for my A8 is $300 CDN, so with the conversion my estimate is slightly higher. You say it worked great on your A4. Was the procedure done separately or in conjunction with other engine service, i.e. can you be sure the benefits were due to the burnout?
I am gonna have it done once a year. it was of course in addition to service, it came about when I asked them to clean the ICV valve and the throttle body. I chevron cleaner once in a while butwhat they did really rocked. The car stayed very good for months until of course deposits re appear. The A8 is a big engine and I believe it will make it more good than bad. Do a search on BG 44 on all forum and see some of the feedback.
Like I said I will do it once a year. I should have done it the first day I got my car, the first owner lived in NYC and never left the city. talked about deposits.............
I was caught in the middle of I-5 at midnight once many years ago and the fuel filter clogged up to a point that I caould not go more than 10 mph. By luck I had a can of Techroline in my trunk. Added it to the fuel and in a few minues I was able to get the engine running to higher and higher RPM. If it can open the gunk from the fuel filter, it can help with keeping valve stems clean.
yeshia
01-17-2013 10:23 AM
b-thumper
09-10-2003 08:31 PM
(eom)
02-10-2000 02:46 AM
