Miss-firing
I have a problem which is VERY reminissent of an old issue i had.
I recently started my car to find that it sounds very 'rough' and the cat light has come on.
The last time this happened (which was about 2 years ago) i had it checked by audi where they said that one of the ignition switches had malfunctioned.
Each cylinder has one and as one had failed it was only firing on 7 cylinders (hence the cat light because there was unburnt fuel going into the cat)
My questions is this:
the part they replaced is part number V4D0 905 351 909029/CONT-UNIT
and i want to know if i ordered the part myself if i could replace it myself. Is it difficult (they charged over 2 hours labour before) and is there any other work that will need to be done post the fix. Also would i need any fancy tools?
many thanks
chris
many thanks
chris
i've been reading through the audiworld forums and can use my vagcom this evening to find out the cylinder number which is misfiring.
will this be easy to physically locate ? and (paulw i'm hoping you can help) is that part i mentioned going to be easy to replace once i know which of the eight it is malfunctioning?
thanks in advance
c
thanks in advance
c
that's what it says on the invoice. When i spoke to audi to enquire as to the part - i have them the V4D0 905 351 part and they equated this to a control unit (of which there are 2 in the car)
just off to work so may be tonight my time but buy the part.
It appears to be a control unit /one per bank / for ignition coil packs and looks a b reeze to fit
change a spark plug on the A8 you've already had your hands on it.
Bob
Bob
here is the report :
VAG-COM Version: Release 512.1-UD
Monday,30,January,2006,22:45:52
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
Address 01: Engine
Part No: 4D0 907 557 P
Component: 4,2L V8/4V MOTR AT D01
Coding: 04273
Shop #: WSC 02324
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16692 - Cylinder 8: Misfire Detected
P0308 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D00
No fault code found.
Address 08: Auto HVAC
Part No: 4D0 820 043 K
Component: D2-KLIMAVOLLAUTOMAT D05
Coding: 00081
Shop #: WSC 02324
1 Fault Found:
01592 - Air Quality Sensor (G238)
02
Address 01: Engine
Coding: 04273
Shop #: WSC 02324
4 Faults Found:
Readiness: N/A
Coding: 00081
Shop #: WSC 02324
1 Fault Found:
i am having problem with my 98 a8 quattro missfire code detected at cylinder #3 i swaped the coil with an other one same problem on #3 coil worked fine in an other cylinder, i dont get any sparks from #3 at all i see 3 wire going in one is reading 12v when it is unplugged same as other cylinders, when i plug it in third wire reads 12v as well like ither working coils, i dont know what i should get from the wire in the middle, that must be the trigger and that is the only one that i couldnt trouble shoot. what do u recommend
04AudiA8L
10-28-2009 02:50 AM
Sleeper1.8T
01-17-2008 07:54 AM
02oettingerA4
9
02-04-2003 04:12 PM
