My 2003 S8 overheats with AC on when stuck in traffic
everything seams to be ok. All of the fans are working, and I don't know what to look for next. Could it be clogged radiator? Car has 62k miles
That probably means your fan is not kicking on.
Your auxiliary fan should turn on as soon as you turn on your A/C.
When car is cool, turn car on with A/C off. Turn on A/C and see if your fan turns on. If it does then you have other problems.
I'm sure the other guys will chime in and give you more input.
Best of luck.
Best of luck.
Temp switch
I just repalced the temp sense switch in the radiator on my daughters A6.
Same symptoms, even if the failure mode included the fan motors that ran constantly until they wore out the motor brushes.
Check all the parts!! High speed fan, low speed fan, thermal switch, power to the system. There is pleanty of cooling capacity on an A8 if everything is working.
CalG
CalG
He said "All of the fans are working". If the electrical fan doesn't work you can see it.
The mech fan will spin all the time, but you can stop it with a pencil. I've replaced it on both of my A8. The replacement fan clutch is under $100 on ebay.
if fans are running and rad is clean externally...
then you have a stuck thermostat, internal rad core obstruction, or water circulation problem e.g. (pump, hose, airlock)
if you run the heater full blast it should drop the gauge a bit.
but, with engine off and hot, mech fan should have moderate resistance to turning by hand and not wobble more than 3mm or so. It has to turn fast enough to move some air. it should spin more freely when cold (thermal clutch) for power and noise saving
