Need some Help with somebody with MFSW
Basically, I think anybody with an 00 and newer car with a MFSW. Maybe somebody already has a picture of this....
However, I have everything all set for my retrofit, but there is a 2 pin connector at the top of the self cancelling ring that is on the car side (stationary side) of the wiring harness. I do not have the 2 pin connector for it, but I do have repair wires that I can just slide on the contacts. The self cancelling ring IS NOT marked with "1" and "2" that I can see. So I need to figure out which is ground and which is power.
One wire will be brown (ground), one will be power (black/red). My steering wheel has no connector there because it's not multi funciton and heated.
<img src="http://www.audipages.com/upgrades/steering4.JPG">
It's the top two pin connector here:
<img src="http://www.audipages.com/upgrades/sm_DSC_5285.JPG">
Here is the schematic:
<img src="http://www.audipages.com/upgrades/sm_DSC_5290.JPG">
And the correct cancelling ring was the AL suffix:
<img src="http://www.audipages.com/upgrades/sm_DSC_5276.JPG">
I was able to take the top cover off by undoing the two Phillips head screws (number 8), but I did not get it back on yet, at least easily. I know if you took the steering wheel off, you could get it back on easy. Maybe somebody already has a picture or an idea.
<img src="http://www.audipages.com/Tech_Articles/electrical_equipment/ignition11.gif">
Re: Need some Help with somebody with MFSW
<center><img src="http://pictureposter.audiworld.com/83025/audi_a8l_2001_mfsw_wiring.jpg"></center><p>Paul,
Here is a picture of my 2001 A8L with factory equipped MFSW. Brown wire is nearest turn signal stalk.
Paul
Paul
@ PaulW
First off, congratulations!!!
I am retrofitting the MFSW, too.
Do you still have the circuit diagram and the information where you connected the cables incl. the plugs and so?
May I kindly ask you mail me those?
Thank you!
Thank you!
Scottrhartman72
10-08-2017 04:37 PM
MoAK
04-09-2005 08:00 AM
jfischetti
05-27-2004 06:43 AM
Scott Long
12-25-2001 06:05 AM
