Need some tire help.
So i have my new wheels arriving in a couple of days, and i'm looking into tires.
the rear wheels are a 19x10
and the front are a 19x9
the tires i have been looking at getting are the Toyo T1R
for the rear i was thinking a 265/30/19
and for the front a 235/35/19
buuut, this only gives me a load rating of 91 in the front and 94 in the rear... so is this really dangerous, or is it okay to drive on this?
i want to do a slight stretch on the rear and the front if possible, as i still would like to tuck them if i can.
any suggestions or do you think its okay to run them?
Most brands of 255/40-19 tires have an approved rim width of 8.5-10". This size tire provides absolutely no "curbing" protection to a 10" wheel, but performance and handling is undoubtedly maximized.
Your much taller profile 245/50-17, on the other hand, has an approved rim width of "only" 7-8.5"<ul><li><a href="http://www.audipages.com/upgrades/tiresizeoptions.html">A8/S8 Tire Options</a></li></ul>
IMHO, the huge wheel gap with such small diameter tires will look terrible on an A8 (to say nothing of the very low load range of the front tires).
For a staggered setup, I suggest ...
Front: 245/40-19 on the 19x9 wheels
Rear: 285/35-19 on the 19x10 wheels
Load range is not a problem with these sizes, and there's only a 0.5% difference in circumference. To minimize the increased understeer, I also strongly recommend that you installed the S8's heavier rear sway bar on your A8.
<a href="https://forums.audiworld.com/a6/msgs/110254.phtml">A6/S6 Tire Options</a> [Note 3600+ views!]
