The New "MOTHER OF ALL PROCEDURES" Doug Banning's TB Replacement Procedure
#11
Paul,
Good to see you back from Florida, If you do a search for "oil cooler", the thread will come up. The following is the shortcut. Sorry I haven't posted a link before and the following doesn't look as if you can click it.
https://forums.audiworld.com/a8/msgs/19076.phtml
#12
attached to the metal bits. If the mount needed replacement, it would be a relatively painless procedure. (No need to remove the TB cover to replace it.)
#14
My guess is in your case one of two things has occurred- the damper has delaminiated and must be replaced, or another possibility is that the passenger side TB cover has shifted and created a gap between the damper and the cover mount. The best way to check this is to remove the top bolt from the damper that holds it to the TB cover, and check for any gap between the cover and the damper. If there is more than a 1/8" gap, then the cover has shifted or the damper is really messed up. When they replace the damper, make sure that the gap is checked and is OK.
lgranch1
02-01-2007 12:59 PM
SawyerA8
11-24-2005 09:37 AM
somu76
Audi 100 / A6 (C4 Platform)
11-27-2003 08:32 PM
