New BMW 5's series are bigger than our A8? My wife swore that her friend's new BMW 530 is longer,
wider and taller the our A8? Is this true? I need to get the specs for these 2. I always thought that the 5's are the same as the A6.
2004 BMW 530
Wheelbase 113.7"
Overall Length 190.6"
Curb Weight 3,472 lbs.
Cargo Capacity 14 cu. ft.
Seating Capacity (Std/Max) 5/5
Front Headroom N/R
Front Legroom N/R
1998 Audi A8 SWB
Exterior Dimensions
Wheelbase: 113.0 in.
Front Track: 62.6 in. (1591 mm)
Rear Track: 62.2 in. (1580 mm)
Overall length: 198.2 in. (5034 mm)
Overall Width: 74.0 in. (1880 mm)
Height (unloaded):56.7 in. (1440 mm)
Ground Clearance:4.8 in. (123 mm)
Curb Weight: 3682 lbs. (1670 kg.)
Wheelbase 113.7"
Front Headroom N/R
Front Legroom N/R
1998 Audi A8 SWB
Exterior Dimensions
much heavier :-(
Length .... 7.6" longer (198.2" vs 190.6")
Height .... 1.2" lower (56.6" vs 57.8")
Width ..... 0.8" narrower (79.0" vs 79.8")
Weight ... 585 lb heavier (4068 lb vs 3483 lb)
<A HREF="http://www.bmwusa.com/vehicles/5/530iSedan/techdata.htm">2004 BMW530 specs</a>
<A HREF="https://www.audiworld.com/model/historical/00/a8.shtml">2000 A8 specs</a>
And less roomy too. The BMW may appear spacious due to the 'exposed' interior (which I don't like one bit), but the A8/S8 surely has more room. ;-)
smooth line of the A8. The BMW butt is large, tall, and the body look so much thicker than the A8. Well it does look bigger but I guess it's not. You can't argue with the specs.
Thanks,
Thanks,
And the Audi is made of aluminum. Damn. Is anyone familiar with the particulars of this weight difference? Yes, additional running gear for Quattro is part of it, and yes, the Audi's a slightly larger car, but does anyone know about the rest? Sheesh, 600 lbs is equivalent to a couple NFL tackles as permanent passengers.
DriveFastTakeChances
S6 (C7 Platform) Discussion
12
05-16-2017 12:22 PM
willythekid
02-19-2006 11:57 AM
STEVE2.7T
05-24-2003 04:43 PM
Aries
11-13-2002 07:50 AM
jambaj0e
11-07-2002 11:26 AM
