New Throttle Position Sensor - 24 hour Report
#11
Comparative values on the TPS that arrived today. (It's -3 out there, so waiting for a warmer time to install)
With the handy DVM
1-2 = 2.165 k ohm
2-3 = 1.063 k ohm
2-3 = Wot 2.898 K OHM
AND JUST FOR YUKS 1-3 = 2.838 k ohm & .948 k ohm
Closed throttle position works fine! open/closed
Where there is life, there is hope!
CalG
With the handy DVM
1-2 = 2.165 k ohm
2-3 = 1.063 k ohm
CalG
#12
The evidence seen by logging groups 7 and 9 in the transmission (Thank you VAG-COM) suggests as much Ground, or flakey variable resistance, when the signal starts at five volts, and passes through 1-3 kilo ohms, small changes can mean big problems!
I truely hope we can put an end to this witch hunt! I'm working on a Storage O-scope to better characterize the TCM inputs and outputs. BUT This TPI sitting next to me sure looks sweet!, Heck How many actuations does a throttle get in 100K and 7 years? I wouldn't expect a longer sevice life, but that the defect shows in the transmission is just sinister!
Perhaps all fale hope. I wait for the data logs after the change.
Paul: The proof is in the putting.( putting on the replacement hardware!)
Now, what should we do about that thump?
? Log the N218 performance and look for an abrupt transition due to ??????
CalG
CalG
Francisco -Altenio Diaz
A4 (B7 Platform) Discussion
07-28-2018 02:38 PM
snowman '92 100
12v V6 Discussion
01-05-2006 10:34 PM
Kris Hansen
07-11-2002 05:21 AM
