Next issue. Please give me some ideas. No reverse, and no R in the dash. BLANK.
#11
It got stuck in full auto, no manumatic.
The switch was broken. for the lights you either have a broken or loose connection somewhere(check the rear driverside doorjam). Does the window work on that side?
#12
Yes the window works, and the backlight on the window switch works, so there is power going into the door. A few months ago it would not work, but if I opened the door and closed it a few times, it would work for a while.
Well I have these choices: drive, park, or neutral. My RC car does not have reverse, but this is an A8! It has a power rear sunshade for gods sake! heh
#13
When the alarm fails to flash one side or the other, which side is it, and have you confirmed that both the front and back do not flash?
No double speed flashing of the turn signal on that side, even occasionally or with the headlights on?
Sorry to take your time with these questions. I'll look at the wiring diagram looking for what if anything these problems could have in common.
Tom
Tom
#15
All lights work 100% when using the parking lights, hig beams, head lights, blinkers. NOTHING funny, ONLY when I arm the alarm.
Thanks for your effort!
#16
... reverse worked instantly.
I shift into N, fine as always.
Into D, fine.
Into 4 display stayed on D
Into 3 display stayed on D
Into 2 worked fine ( was BLANK before).
Shifted UP into 3, fine. Huh?
Into 4 display stayed on 3
Into D display goes to D
Into N, fine.
Into R, fine.
Into N, fine.
Into D, fine
Into 4 stayed on D
Into 3 stayed on D
Into 2 jumps to 2.
Into 3, FINE.
Into 4 stayed on 3.
back to 3, FINE
first time 3rd has worked on the way DOWN to it.
back to 2, fine.
back to 3 fine
back to 2 fine
back to 3 fine
looks like 3 is fine now.
shift to into 4. FINE.
first time 4th worked again.
Tried them all, one by one, all seems to be well NOW.
Now I am really thinking F125. Anyone else?
Into D, fine.
Into N, fine.
Into R, fine.
Into N, fine.
Into D, fine
Into 4 stayed on D
Into 3 stayed on D
Into 2 jumps to 2.
Into 3, FINE.
Into 4 stayed on 3.
back to 3, FINE
back to 2, fine.
back to 3 fine
back to 2 fine
back to 3 fine
#17
Switch F125, if broken in a weird way could be the problem. Another remote possibility is that the main fuse for the TCM is blown or making a bad connection, yet sometimes the TCM gets enough power to operate not from its normal power wire but from wires from the separately fused F125 switch (not exactly impossible depending on what's inside the TCM). The TCM fuse is in the corner of a fuse & relay panel in the electronics box just ahead of the windshield in the passenger side.
No PRND432 means no communication from the TCM which is why I'm wondering more about power than the F125 switch.
The switch supplies battery voltage to the TCM on various wires according to shifter position from a separate fuse (fuse 6 in group 3 in the ordinary fuse box). We know this fuse is good because it operates the backup lights.
If you do decide to unplug the TCM for troubleshooting or contact cleaning, disconnect the negative battery terminal first.
The other electric problems have no obvious relation to the transmission. The alarm box itself has separate left & right turn signal connections, so that issue is not likely to be outside the alarm controller or its connections.
Tom
Tom
Gator Neil
A6 (C7 Platform) Discussion
02-01-2013 07:03 AM
kinderutz
Audi 100 / A6 (C4 Platform)
10-18-2008 10:18 AM
jjguitarranch
10
08-08-2005 09:12 PM
Oettinger_A4
12
11-17-2003 07:21 AM
