Sponsored by:
Sponsored by:
Is it normal to have to put new brake pads with a hammer?
Old 07-07-2008, 06:19 PM
  #11
mart_o_rama's Avatar
Default The source of my problem...
<img src="http://pictureposter.audiworld.com/68260/dsc00337.jpg">
Are those the "guide pins" beneath the pad? If so, then the fact that they are at an angle, not flat horizontal, is why i'm having a hard time fitting the new, thicker pads back in.
This picture shows a pad that I filed fairly intensively to get it in the caliper. Only the backing plate luckily and not the actual brake pad material.
Also, check out the old pad:
<img src="http://pictureposter.audiworld.com/68260/dsc00335.jpg">
I don't know what to think of it besides that the caliper simply doesn't look to be doing a good job...
So right now I have one caliper with filed pads that fit properly and "move", and one caliper with a pad that I jammed in with a hammer. I tried to remove that pad but it was of course stuck but I could jiggle it a little sideways so I thought "good enough!" but perhaps no. Time will tell. Right now the car stops fairly effectively, but I recall the S4 was much "grippier".
Cal G, thank you for the nice write-up, I do believe some of my pistons are perhaps close to being seized. One of my next job will be to remove the complete calipers and disassemble and clean.
Martin
Old 07-07-2008, 06:59 PM
  #12
Perpetual Novice's Avatar
Default 2nd that
I did 3 front end brake jobs on the A8 before I clued in. I would always get horrendous squeal.
Now I know to clean and lube everything: for me it was especially important to get the guide pins cleaned and lubed.
Old 07-08-2008, 01:26 AM
  #13
Always Overcharged's Avatar
Default Guide pins-never seen them before-is it something the last owner did
to reduce squeal????
I added a tensioner clip that mounts beneath the caliper and puts pressure laterally on the pad stopping unwanted shudder and reducing squeal as much as 80%
Old 07-08-2008, 02:37 AM
  #14
Junior Member
TOMAS7's Avatar
Default Re: Guide pins-never seen them before-is it something the last owner did
Please explain your tensioner clip. Can you give me a little more detail.
Old 07-08-2008, 06:14 AM
  #15
Elder Member
ryoung's Avatar
Default Looks like the source of your problem got twisted out of position.
On my Brembo's, that piece of metal is perfectly horizontal and flush up against the inside wall of the caliper. As you know, it's actually an L-shaped piece of metal (you can't see the bottom of the "L" in the pic) that keeps the pad from falling thru the caliper.
<img src="http://pws.prserv.net/usinet.Young/photos/Brembo_with_pads.jpg">
Old 07-08-2008, 08:44 AM
  #16
Will that piece of metal come out if I take the entire caliper off the car and disassemble it?
Old 07-08-2008, 10:43 AM
  #17
Default Audi NZ christchurch branch suggested and supplied it-bolts on to back of
caliper using main bolts and simply puts pressure on the pad to stop movement.
Ask at your dealership and if they dont know have them ask Simon at Archibalds Christchurch franchise
Old 07-08-2008, 01:56 PM
  #18
Junior Member
TOMAS7's Avatar
Thank you.
Old 07-08-2008, 09:18 PM
  #19
Elder Member
ryoung's Avatar
Default IIRC, they're very easily removed and ...
You shouldn't need to remove the caliper from the car. I moved last year, and my old Brembo's are in a box somewhere. If I can find them, I'll double-check.
cybspi
11
03-11-2009 10:06 PM
bac2h
06-13-2006 10:51 AM
CP
Performance and Tuning
09-18-2004 04:20 AM
AW #29529
10-06-2002 06:57 PM
Jenner
06-07-2001 08:21 AM
Quick Reply: Is it normal to have to put new brake pads with a hammer?
