Oil Leak
I just purchased a used '99 A8, and have a small oil leak. What I have noticed is oil dripping from the bottom of the oil filter. I changed the filter, o-ring and washers, hoping maybe it was one of those. The leak is still there, and seems to be coming from somewhere higher up on the engine and running down. I have read about the Camshaft seals, and the breather tubes. But was wondering which one of the 2 of those usually show up as drips from the filter? Or is it leaking somewhere else?
I checked the valve covers, and they are both pretty dry, as is that side of the block. The top of the oil filter housing looked a little oily, as does the oil pressure sender. Maybe a leaky oil pressure sender? Has anyone seen this before?
<center><img src="http://pictureposter.audiworld.com/87363/p1010004.2.jpg"></center><p>
<ul><li><a href="https://forums.audiworld.com/a8/msgs/157034.phtml">Yeah! Something cheap and simple for a change!!!!!</a></li></ul>
LarryJa
12-04-2017 05:56 AM
dimitristx
08-06-2003 12:43 PM
