Oil Leak continued. I need diagnose doctors!!!!!
#11
Re: Looks like mine
Yep..that was my source of a small leak, right there. Changed the oil cooler pipe and O-rings thinking that would do the job but leak still there. Oil sender unit area dry. Took of front TB cover on right side and, sure enough, gasket seam behind oil pump oozed new oil after I would clean it off and then run engine. Had just changed TB so I bagged the replacement job. I wipe off of the plastic cover every so often and have put an old piece of carpet under the area to effectuate my "cure".
Craig
Craig
JMS-Four
01-30-2007 10:38 AM
UrSoccer_mobileĀ®
12-23-2002 03:42 PM
