OK, got the VAG tool and the Bentley CD. Now, direct me to how to...
#11
Jumpers from where to where?
Judging by ETKA the switches are all identical, so their functionality shouldn't be an issue. What actually regulates the auto up/down? Could it be as simple as swapping a relay/module?
#13
If operated from drivers position, the rear windows are not within your line of vision, therefore someone or someting could potentially get trapped. (However, they have a pressure safety).
Imho it wouldn't be for children perse, as you can switch off the operation in the back if need be. Personally I'd be mainly interested to operate the auto up/down from the drivers seat. That would be convenient. :-)
#14
There is a procedure somewhere here on audiworld to do it....you just physically add one wire per switch connetor to jump two contacts on the switch and you're in business.
I could not find the link right now.
pw
pw
#15
And following this chart (regardless of what radio/year you have) recode the module to the new number you want.<ul><li><a href="http://www.audipages.com/Tech_Articles/Body/lockcoding.pdf">http://www.audipages.com/Tech_Articles/Body/lockcoding.pdf</a</li></ul>
#16
03: ABS Brakes
01435: Brake Pressure Sensor 1 (G201)
48-10: Supply Voltage --- Intermittent
02: Auto Trans
Coding 00102
18112 - Kickdown Switch (F8): Electrical Malfunction
P1704-35-10---Intermittent
Ideas?
02: Auto Trans
Coding 00102
Ideas?
#17
to accept anything but the 00102 that is the original (default) setting (it's a '01 S8). I guess the S8 does not, indeed, accept anything else.
#18
..(per the f&*&ing Bentley), I opened the Audi Manual and saw where the thing was supposed to be. Thanks, Bentley!
bac2h
11
04-23-2012 11:09 AM
QTip 2.7T Converted
Pacific Northwest Discussion
17
03-28-2004 09:59 AM
slimcubby
11
03-25-2004 11:42 AM
2faS4u2pass
11-07-2001 02:11 PM
