Ok one more try... What the hell do I do Code- P0441....!!!!!
About a month ago I had a different code error I thought, I had the same code this time, so I went back to find Paul W post and it turned out it was 0491 i had not 0441. Last time I just put some injector cleaner, cleared the code and ran my car for 1200 non stop.... never came back on. Now this one............... What do I do any suggestions
using the procedure I posted? If so and you're still getting the code, then check the EVAP canister hose connections for leaks(under the spare tire):
<img src="http://i255.photobucket.com/albums/hh156/ricoblanco/EVAPcanister.gif">
Finally, check the Leak Detection Pump connections by removing the drivers side rear wheel well cover to access it:
<img src="http://i255.photobucket.com/albums/hh156/ricoblanco/LeakDetectionPumpLDPV144.jpg">
at your local auto parts store. You spray it on the vacuum lines while the engine is running and if the idle changes, that's where the leak is. BTW, I would start by the purge valve and intake manifold before checking the EVAP canister and leak detection pump.
rktskicar
VAG-COM Discussion
09-19-2008 07:44 AM
jazbo123
06-14-2006 06:32 AM
