ok so WTF is up with THIS!
this may be a repost but im curious what everyone's thoughts are on it.<ul><li><a href="http://cgi.ebay.com/ebaymotors/AUDI-supercharger-kit-A4-S6-A8-CABROLET-S4-ST-A6_W0QQitemZ180046845149QQihZ008QQcategoryZ33741QQ rdZ1QQcmdZViewItem">http://cgi.ebay.com/ebaymotors/AUDI-supercharger-kit-A4-S6-A8-CABROLET-S4-ST-A6_W0QQit
I really like the statement:
"DOES NOT RESTRICT YOUR INTAKE when not in operation (air-flow through 3.0" dia. is equal to a 3.1 inch diameter straight tube)"
WOW- these guys will be millionaires!! A 3" diam. device that has better airflow than a 3.1" diam. straight tube! They have discovered some new never-before discovered Physics! Why are they wasting their innovation on a $125 "supercharger"?
Search the A8 forum for electric supercharger....
better have a really good alternator and some large gage wire! The amount of electrical energy required to pressureize the large volume of air required by these engines is quite considerable. If these electric supercharges were productive and reliable, don't you think the automotive manufacturers would have picked up on it?
This device is precision engineered to separate a fool from his money.
CFM tells the story and that is the story he ain't telling. You could blow up a ballon with your mouth and probably generate a few PSI, but what of the VOLUME of air you are pushing....very very very little. PSI is merely a measure of resistance in the system. Without a stated CFM in a known system a psi number is meaningless. PSI is more a measure of compressor efficiency. If Turbo 1 can flow 350 cfm at 10 psi and turbo 2 needs 15 psi to do it, that tells you something about how they behave...one will likely spool slower but produce more on top, two will likely rev quicker. Point is...psi is meaningless by itself. CFM at psi tells you something, and again, that story is not being told. Save your money.
There is but one electric supercharger that I am aware of that is provable and actually works. I don't have his direct site, but here is an article aoubt it:
http://www.turbomagazine.com/tech/0406tur_knight_turbo_electric_supercharger/
It shouldn't take very long at all to destroy your battery.
<img src="http://turbomagazine.com/tech/0406tur_knight02_z.jpg"><ul><li><a href="https://forums.audiworld.com/a8/msgs/83238.phtml">Another Electric Supercharger Discussion</a></li></ul>
