Outer CV boot replacement procedure
#11
1. Pop out center cap and remove drive axle bolt. This is
highly torqued so remove (and install) with the wheel on
the floor. Loosen the lug bolts.
I do not have a bolt here. I have a large hex key slot. What size hex is this and why do I have this and no one else seems to?
Thanks for the help.
#12
While on the subject, here's an interesting link for those with the intelligence to replace only the boot/grease (instead of an inferior aftermarket complete axle) when only a torn boot is involved. A properly cared for OEM outer CV joint is good for a half million miles, unless it's gone way to long with a ripped boot and is actually clicking loud and causing pulsating steering wheel:
http://forums.quattroworld.com/a8/msgs/45872.phtml
#13
How do all the tips show this regular bolt? Odd.
Thank you for the info. Looking for the allen bolt on Parts Geek... no luck, darn.
Very cool that I still have the original front axles. They have the 1996 date on them. My old Merkur Scorpio would be on its 4th set with the same miles.
#14
alms_lefko
02-26-2008 07:26 PM
reefer_bob
01-09-2006 01:34 PM
