P0506 - Idle Air P0506 Control System RPM Lower Than Expected
I am getting this code on my S8 ! Recently i had a leak from the Injectors Seals which i replaced . i have checked the net for the cause its is indicated either from vacuum leak (which is not my case) Damaged/failed/dirty throttle body(I have checked and cleaned ) .An air restriction in the intake air path or exhuust or A faulty positive crankcase ventilation (PCV) valve
Or Internal engine problem (Hope is not this one ) or Failed PCM.
From Where should i begin ?
you might need vagcom to do a throttle re adapt after cleaning it. if not the throttle controller might just be bad. not many things can make the idle lower. air leaks tend to make it higher
b4 audi
09-13-2008 02:37 PM
