Posted this in VAG-COM forum....but maybe somebody here can help
I have a check engine light with a recurring code, 17538/P1130.
When I pull the code and copy the data and paste it in a document it states:
1 Fault Found:
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-00
But when I look the code up in the Bently, it shows:
P1130
17538
Long Term Fuel Trim mult., Bank2
System too rich 1)
My question is: Do you know if this code is actually a lean or rich code? My Bently shows the lean code as 17546/P1138
Thanks!
1 Fault Found:
P1130 - 35-00
P1130
17538
System too rich 1)
Thanks!
But it says lean on this page http://www.bentleypublishers.com/tech/audi/audi.dtc.table.htm<ul><li><a href="http://www.bentleypublishers.com/tech/audi/audi.dtc.table.htm">http://www.bentleypublishers.com/tech/audi/audi.dtc.table.htm</a</li></ul>
Under the diagnostic codes portion where it just lists the fault codes, it shows it as lean.
Under OBD under the engine, it shows it as rich. Just a mis print I guess.
of your vacuum lines, or just the one you mentioned below? The reason I ask is that the code you show is on the <a href="https://forums.audiworld.com/a8/msgs/165940.phtml">TSB list</a> for bad vacuum lines.
If you did all that already, then nevermind...
going on
The code with the next number is rich ie:
17535 = rich on bank 1
17536 = lean on bank 1
so I assume that
17537 = rich bank 2
17538 = lean bank 2
so I assume that
17537 = rich bank 2
17538 = lean bank 2
