Puzzling steering issue
#11
this is interesting, especially this part ...
"Test drive the vehicle and make sure the steering wheel returns to center after initiating a turn, if not the adjustment is too tight. Back off the adjustment slightly and road test the vehicle again."
i'll have to do some research on it. thanks for the info.
#13
<center><img src="http://pictureposter.audiworld.com/77900/adjustment_screw.jpg"></center><p>
Following up ... I came across this in my eBahn Bentley A8 repair manual, "Power steering gear, assembly overview" section ...
Power steering gear, adjusting
Note: Two mechanics are required to perform adjustment. Adjust with engine switched off.
- Raise vehicle on hoist.
- Wheels in straight-ahead position.
- By turning the steering wheel to and fro (about 30 degrees to center axis) a knocking noise will be heard if there is excessive play.
- The second mechanic should carefully turn the adjustment screw (arrow) until the rattling noise can no longer be heard inside the vehicle.
- Carry out a road test.
- Make sure that when maneuvering or negotiating corners the steering self-centers without sticking, re-adjust if necessary.
#16
If the problem really did occur after hitting something, and all the alignment measurements are good, I still wonder about a bent steering rack.
Got enough air in the tires?
Tom
Tom
#17
the tires have enough air. i wish it was as simple as turning an adjustment screw. we've been looking all around for damaged/suspect components like the rack, servo, control arms, tie rods, sway bar links, etc, but nothing so far. so we're still scratching our heads.
#18
Steering Axis Inclination (SAI). This the one causing the steering wheel to come back by it self after a turn.
Ask your mechanics whether they measured that one.
#20
i meant to say i hope it would be as simple as loosening the adjustment screw. i haven't tried it yet. i'll keep you posted.
