Sponsored by:
Sponsored by:
Puzzling steering issue
Old 05-03-2007, 05:42 PM
  #21
deml0's Avatar
thanks. i'll pass that info to my indy.
Old 05-03-2007, 05:58 PM
  #22
Angus Beef's Avatar
aka: King Pin Angle
Old 05-04-2007, 05:09 AM
  #23
A8CT's Avatar
Default Ok, I tried this last night w/o any success
You access this on the drivers side, around the tie rod cut-out (take the wheel off). I'm confused on the terminology in the Bentley in that its says adjustment "screw".
I assume it's the 18mm nut that they are referring to. If so, I couldn't get any movement on it but you really need a LONG 18mm wrench with an offset. You might be able to come up from underneath with a socket but it's not a straight shot. I was a little pressed for time and will try again.
Bob
Old 05-10-2007, 05:39 AM
  #24
deml0's Avatar
Default Re: Puzzling steering issue
Follow-up ... Apparently hitting the wooden post caused more damage than I suspected. According to my indy, turns out the steering issue was due to a combination of arms and bushings, and steering knuckle assembly. They were all replaced, as well as the CV boot which tore off. Thanks everyone for your comments and advice!
Next up ... fixing the fender.
dh53
07-31-2018 01:24 PM
Bryce Chang
03-06-2018 12:33 PM
Decim8r
S6 (C7 Platform) Discussion
08-14-2014 06:04 AM
pearsondarryl
08-06-2013 07:20 AM
Afroney
04-12-2003 09:06 AM
Quick Reply: Puzzling steering issue
