Reason why the A8/S8 has/had a timing belt rather than a chain?
weight, simplicity, noise. Timing chains need maintenance too. Either way, belt or chain, you need to R&R it once during a reasonable lifetime. At 105 K mis for the belt, or 140 K mis for the chain idler &c.
A timing belt prevents the transmission of crankshaft harmonic vibration into the valve train, which results in more accurate valve timing.
<img src="http://www.jesel.com/images/beltdrives/beltdrive1.gif">
<img src="http://www.jesel.com/images/beltdrives/beltdrive2.gif">
will not keep their cars until it needs to be changed. I think that as with the lifetime fluids they are marketing a car that does not need maintenance. It makes it more attractive to customers that know little about cars and only want to get in and drive.
