Rebuild tranny back in the car, now getting P0102
Well, I almost there. Finally got my rebuild tranny from Phoenix back in place last weekend. I also replaced valve cover gaskets and now engine does not run the way it was before. As soon as I start engine it runs good for a few seconds and then it starts choking, almost like it gasping for air. As soon as you touch the throttle - it quits. What the hell? It runed perfect last time I started it (3.5 months ago, just before I removed failed transmission). I checked all connections, sensors and vacum hoses probably dosen of times and getting nowhere. Finally my brother came with Generic Scan Tool and we pulled "P0102 low input". Is it a MAF sensor giving me a headache now? But why? nothing has changed since last time. When I got the code I had connection tube between air filter housing and intake hose removed. I cleared the codes, installed a connection tube back in place and tried to start the engine again to see if code comes back. Nothing. Engine is not running at all now. And no codes either. My brother saying it must fire at least for a couple of seconds to get a code, is that true? Anybody had a similar problem? Thanks.
Check if you put back everything. With my engine support tool, I have to remove the cruise c, actuator. That has a vacuum hose too. Also make sure that you put back the spacer under the engine speed sensor. (driver's side of the tranny) It will not run if it doesn't have a correct gap between the sensor and the flex plate.
I dont know what the hell is going on now. Checked everything, there is a spark on spark plugs, there is a fuel pumping fuel ( but may be lower than usiall), now it doesnt even fires once. Think going to take it to the shop finally next week.
for the sensor. Pull it out and see if the gear lines up with the hole. The distance between the sensor and the flex plate is around 1.5-2mm. Maybe the spacer you have under the sensor is too thick.
saifxnyc
04-29-2016 12:50 PM
thecouga
12v V6 Discussion
10
12-03-2005 05:23 PM
schnitzelboy
10-31-2004 09:14 AM
JFitz_2000_4.2
02-07-2004 08:08 AM
