removing bumper cover
can someone please give me instruction on how to remove the front bumper cover?
Do you have to remove the bumper first?
If anyone could e-mail me a Bently printout I would really appreciate it.
Thanks!
Thanks!
Audipages is your friend ;-)
Also, to answer a question form an earlier post, if the "L" shaped bracket on the bumper cover is broken, it can sometimes be repaired. I fixed mine using a piece of angle aluminum that I drilled and pop riveted to what was left of the plastic "L" piece on the cover. I then epoxied it as well. You need to be sure that the vertical section of the aluminum angle is at the correct distance from the cover, or it won't align properly.<ul><li><a href="http://www.audipages.com/Tech_Articles/Body/frontendremoval.html">http://www.audipages.com/Tech_Articles/Body/frontendremoval.html</a</li></ul>
jguthrie
08-13-2005 05:36 PM
Stoney
14
08-05-2003 02:44 PM
Pekboy
11-21-2001 02:19 PM
