Request for ETKA experts
Can anybody tell me if the self cancelling ring for the steering wheel (clock spring) part number is the same for an 01 S8 as an 03 S8?
Basically I need to cross reference my 01 S8 (sport steering wheel with tiptronic controls) with an 02/03 A8 multi function steering wheel with tiptronic controls or a 03 S8 which is multi function with tiptronic controls.
I have ETKA, but I am not good at finding info in it.
For those who don't know what a self cancelling ring is, here's a picture:
<img src="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/sw5.JPG">
<img src="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/sw7.JPG">
...cars that have 3 spoke wheels and cars that have 4 spoke wheels. However, there is a TON of part numbers for the cancel ring....I count 14 different part numbers! EDL or no EDL, ESP or no ESP, etc etc....there is ALSO a ton a VIN splits. It DOES make a distinction between multi-function and no multi-function though.
If you want me to dig a little deeper, I can, but it will have to be later tonight. Otherwise, look at ETKA ill.# 959-30.
Etka 7 lists one part number for the cancelling ring that can replace multiple other previous ones: 1J0 959 654 AL.
The notes in Etka state:
"When 1J0 959 654 AL is used in place of
1J0 959 654 AD/AE/AK/AM/K/Q then the
jumper wire for the return spring
to the steering wheel on the old part
is to be used."
is to be used."
I need the PR numbers and VIN # of the vehicle you are planning to get the parts from. If we use this website http://igorweb.org/equidec/ with the PR numbers and then by crossreferencing them to the ETKA part numbers we will figure out exactly what we need. Or if a fellow AUDIworlder who has this factory option, can give us his VIN# and his PR #'s we can still figure out the needed part numbers. Here are the PR Numbers from ETKA related to the slip ring.
1MR = leather steering wheel
1AH = electronic differential lock (EDL)
2C7 = safety steering column with electric axial and inclination adjustment
2PR = leather steering wheel, heated
2ZM = leather trimmed multi-function steering wheel
2ZQ = leather trimmed multi-function steering wheel for airbag system
1AT = electronic stabilization program (ESP)
2ZP = leather trimmed sports steering wheel for airbag system with Tiptronic and "S"badge"
2ZD = heated leather trimmed multi-function steering wheel with Tiptronic
2ZS = leather trimmed multi-function steering wheel with Tiptronic
I suppose you want to modify your car to option 2ZQ or 2ZM, the question then becomes the VIN Number.
From VIN 4-DX-004-165>>4-D1-005-862 PR options 1AT and 2ZQ you get part number 1J0 959 654Q.
From VIN 4-DX-004-165>>4-D1-001-986 PR options 1AT and 2ZM you get part number 1J0 959 654Q.
From VIN 4-D1-005-863 >>4-D2-000-386 PR options 1AT and 2ZQ you get part number 1J0 959 654AG.
From VIN 4-D2-000-387>> PR option only 2ZQ you get part number 1J0 959 654AG.
Now if 1ZM has no airbag then the part # you need is 1J0 959 654AG. But again I can not be 100% sure. Please check the logic too![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Hope this helps
Hope this helps
yrk2.7t@curbside
14
08-30-2007 06:41 PM
