rns-e retro fit
hi guys
ive recently just brought myself a 2002 s8 and i have to say what a fantastic car! this week i have retro fitted a a4 rns-e to it following a thread on here, it all seems to be working as it should apart from it stays on when the ignition is turned off and there is no button illumination both are which i have read linked to coding the unit, today i have hooked vag-com up to it but are getting the same error on both module 37 and 56 saying that there is no connection, i have tryed connecting to other modules within the car and they all seem to work so now i,m stummped! any ideas please
al
al
alex
Here is a post that explains the Can wiring. http://forums.quattroworld.com/a8/msgs/383.phtml
The K line goes from the OBD II port to the radio so you can connect to the radio with vag-com.
all sorted! bypassed the tmc unit, and connected the can high and can low wires to the rns-e terminals 9 and 10 and it now turns off when i remove the key and all the bottons light up! although when i try to connect with vag com it still says not connected when i go on radio or nav module??
