Rough Idle problems...
ive been suffering with rough idleing problems for quite a while now... recently i discovered that my mechanic had earlier replaced my sparks with generaic sparks with 3 tips (no Bosch +4 as in OEM) during a tune-up
he claims that the qualityof the plugs is high and that this is not the reason for the rought idle.
VAg usually throws up a "random cylinder misfire" code now and again...
can these spark plug be the reason for the missing?
<center><img src="http://us.st11.yimg.com/store1.yimg.com/I/rodi_1877_56889609"></center><p>
wait for results between 3 and 10 days depending on how much you drive. If this solves it, replace the fuel filter. The problem may still return: try again with Techron.
I have had the same problem: airbil and PaulW looked at it and solved it with Techron. Replacing spark plugs didn't make a difference.
See all my Techron promotions by doing a forum search for "Techron" and account number 31455.
See previous post:<ul><li><a href="https://forums.audiworld.com/a8/msgs/46239.phtml">https://forums.audiworld.com/a8/msgs/46239.phtml</a</li></ul>
I'd run a tankful of Amoco Ultimate. That cleared up a failed emissions test for a co-worker of mine. I might even be cheaper to run every third tankful. Ultimate has a very high detergent package and I run it all the time.
My 2C
My 2C
CrappleZero
15
01-08-2004 08:13 AM
odelay12v
09-08-2003 05:57 PM
Dars
04-18-2003 01:00 AM
