S6 PLUS / technically S8
#11
AC Volts will tell you if you have a strong enough signal and Hz will tell you if it's plausible.
Is that pic of the gap in the reluctor to signal the crank angle? If you rotate the crank do you see the reluctor teeth? Sensor clearance should be something like 0.8mm but obviously to the teeth and not the gap between the teeth.
jruell
07-24-2014 07:41 AM
xBLACKx
07-06-2010 10:52 AM
Audi200T5000S
04-02-2003 12:47 PM
