Security Codes
Security Codes
Just looking at the security code table and am wondering if there's another code aside from 15208 that allows one-touch lock, auto lock, remote window control AND horn honk (instead of NO horn honk)?<ul><li><a href="http://www.audipages.com/Tech_Articles/Body/lockcoding.pdf">http://www.audipages.com/Tech_Articles/Body/lockcoding.pdf</a</li></ul>
Add 4, 8, 16, 32, etc to add or subtract functions from your present coding
Just follow the table. Write down your original code, figure out what you want to add if it's not there, then add that number to your recode, then see if it worked....or if you want to remove that function, subtract it from the number.
Just make sure you write down your original code.
