Service in 2 flashing on a 97 A8
Just purchased a VAG-COM cable so I can pull and clear codes.
After having an oil and filter change from a local shop, I noticed a flashing Service in 2 light on the instrument cluster next to the odometer reading. Searched the forums and came up with the suggestion of clearing the instrument cluster with the VAG-COM software, but still have indication. How do you clear this indication?
PS Just cleared a bunch of codes and recoded the trans. Codes are posted below:
12 Faults Found:
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-10 - - - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-00 - Please Register/Activate
16689 - Cylinder 5 Misfire Detected
P0305 - 35-00 - -
16692 - Shareware Version. To Decode all DTCs
P0308 - 35-00 - Please Register/Activate
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-00 - Please Register/Activate
16690 - Cylinder 6 Misfire Detected
P0306 - 35-00 - -
17916 - Shareware Version. To Decode all DTCs
P1508 - 35-10 - Please Register/Activate - Intermittent
P0300 - 35-10 - Please Register/Activate - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16691 - Shareware Version. To Decode all DTCs
P0307 - 35-00 - Please Register/Activate
Readiness: N/A
Trans Control Module
1 Fault Found:
17087 - Brake Switch B Circuit Malfunction
P0703 - 35-00 - -
12 Faults Found:
P0305 - 35-00 - -
P0306 - 35-00 - -
Readiness: N/A
1 Fault Found:
P0703 - 35-00 - -
Thanks, will try.
PS What's with the ECM incorrectly Coded code I'm getting?
Is it possible that the shop I took the car to changed the code from factory? Should I attempt to recode the ECM to what the service manual states?
archimense
VAG-COM Discussion
05-15-2006 10:51 PM
BoneStockS4
10-13-2005 11:31 AM
hadokenny
VAG-COM Discussion
09-11-2004 06:43 PM
