Since i replaced my axle my ABS is acting up..
Its going nuts below 5 mph.. every time i stop. Do you think i mis aligned something or mabye i got some gunk in the abs sensor?
ABS sensor somehow misaligned or something. Remove wheels, inspect both sensors and make sure they are clean and inserted fully. Also make sure that the Axel you installed has the serrated "teeth" (for lack of a better description) properly located. Also check the wires and connector that lead to the sensors.
# of teeth was incorrect, which would cause the ABS system to malfunction. Something to think about and check when you buy rebuilt axles...
audiDTM
08-13-2005 09:10 AM
