Sponsored by:
Sponsored by:
Slipping & sliding on ICY road
Old 01-17-2006, 04:59 PM
  #11
New Member
A8L_Driver_Dan's Avatar
Default If you like Michelin, look at the Pilot Alpin PA2
I've had them on for two seasons now. We experience about 12 feet of snow a winter, so I drive through a lot of it for months on end. I have never had a slippage problem with these tire and found them to be a decent performance (albeit winter) tire. They seem to wear better (longer tread life) and not make as much noise on wet roads...something that really bothered me with Blizzaks. Now, we don't have very hilly terrain here so I can't speak to mountain climbing with them.
I also found it easier to buy a second set of wheels and keep the foul-weather tires mounted and balanced.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&amp;url=%2Ftires%2Ftires.jsp%3FtireMak e%3DMichelin%26amp%3BtireModel%3DPilot%2BAlpin%2BP A2%26amp%3BvehicleSearch%3Dfalse%26amp%3Bpartnum%3 D26HR6PA2%26amp%3BfromCompare1%3Dyes%26amp%3Bplace %3D0">Lin
Old 01-17-2006, 05:46 PM
  #12
Elder Member
ryoung's Avatar
Default ABS and glare ice.
ABS works by releasing the brake on a tire that has locked up on a low friction surface, but there's one big catch. ... The ABS computer must first be able to determine that something's wrong.
At least one tire must have enough traction to keep rotating to allow the computer to determine the car's speed. On ice with near zero traction under all four tires, any braking causes all four tires to immediately stop rotating. You're sliding down the road, but the ABS computer thinks that you've already come to a stop! ABS isn't pulsating because it doesn't know that anything's wrong.
The only solutions in these conditions are chains, studded tires, or not driving.
Old 01-17-2006, 06:32 PM
  #13
New Member
SteveIAS8's Avatar
Default Interesting!
Makes sense, Randy. I learned something new tonight.
My situation encountered was not on an ice situation. I'll have to "play" on an open icy parking lot next time bad weather comes this way.
Steve
Old 01-17-2006, 09:05 PM
  #14
ltooz_a6_a8_q7's Avatar
Default Randy, it really makes sense .... that's exactly what happened. WOW. Thanks!!!
I just have to drive more carefully on the icy road. Like you said, chains or studded tires are needed in those conditions.
Old 01-18-2006, 03:18 AM
  #15
New Member
Keke's Avatar
Abs does not pulsate when the car is on icy surface
Old 01-18-2006, 07:43 AM
  #16
dimitristx's Avatar
good point. exactly the reason why ABS is not as effective on loose gravel.
diablo1
14
02-18-2009 03:30 PM
beep-beep
Audi 100 / A6 (C4 Platform)
11-30-2007 10:08 AM
SF_TTMT6
Wheels & Tires Discussion
01-02-2004 01:06 PM
summiTT
04-07-2003 07:41 PM
Treads
01-02-2003 03:22 PM
Quick Reply: Slipping & sliding on ICY road
