So, no leaves bunging up my hole, but this don't look good..
Perpetually confused
so did my gutter clearance drill, but found this coagulating seepage on my tubes... What is it and how would i make it go away and never, ever, come back ?
cheers
<img src="http://pictureposter.audiworld.com/75069/gunk.jpg">
cheers
<center><img src="http://tech.bentleypublishers.com/servlet/JiveServlet/download/24-12700-104603-1029/Pentosin%20G12%20Red%20.jpg"></center><p>
It's pretty much the only thing approved in these cars. No Prestone!<ul><li><a href="http://tech.bentleypublishers.com/servlet/JiveServlet/download/24-12700-104603-1028/New%20Audi%20Coolant.pdf">Audi coolant Technical Bulletin (pdf file)</a></li></ul>
The one on the right appears to be loose. These are the black threaded caps right next to the firewall. Try tightening them so that they seat (don't over do it or they will break!), or with the engine compltetely cool and the coolant overflow tank cap off, remove them and inspect for cracking or missing o-rings. They may need to be replaced.
And we could not find the high point vent plugs/o-rings on the ETKA.
If anybody finds a part number post it, I need them also.
pw
pw
just like everything is available in "limited quantities"- I don't think there is an infinite number of anything :-P Let the marketing department in the engineering door and this is what you get.....
