So, no leaves bunging up my hole, but this don't look good..
#11
...I got rubber rings at the Home Depot that were --almost- identical. It has worked, BUT, I think they don't quite work as well because since that fix I had a radiator hose come slightly loose. After securing that hose again, I got a tiny hole in my radiator. It's almost as if the Home Depot rings don't work well enough and the coolant will find other places to let off the pressure.
#12
If so, are you going to replace it sometime?
I've done one before....they are pretty easy....I'll do it with you.
pw
pw
#13
device. Once you sealed up the high point bleeds with new o-rings, the other leaks were just waiting to be found, not caused by the "wrong" o-rings. Any pressure relief should occur in the overflow tank.
#18
EPR (Ethylene Propylene Rubber) or Polyurathane. EPR is preferred. Any good industrial supply house should be able to get them for you, cost is around 10-20 cents each!
#20
And I'm generally pretty good at finding where stuff is buried.
Glad I have some really good old-school hardware stores nearby, for matching up o-rings, for when the day comes.
