Steering rack hiss / squeak?
Seems like the old girl is throwing me a new problem on a monthly basis. Here is this months issue: On starting her up from a couple of days sitting in the garage I noticed a distinct hissing sound coming from "behind the steering wheel" when the wheel was in the 12 o clock position. After driving the car for some time the noise appears to go away. Starting her up the next day noise was not there either - pressure issue right .....
Also when I turn the steering wheel at low speeds there is a loud squeak, sound like something rubber that needs to be lubed, the two issues are perhaps connected although squeak has been there for a while I think but much louder now.
Issues:
Last 2 year ...
rear upper control arm bushing worn
Rear sway bar loose
Hose poped off radiator - flush and new fluid - $130
Front tie rods need to be replaced
Muffler leak - not fixed cause by removal of muffler by transmission clowns
Cooling fan bearing replacement - $250
ABS wire open circuit - $5
Transmission flange seal leaking - free
2009 - Transmission replaced - $5k but free
Since 2007 - Big oil leak from somewhere .....
Issues:
Last 2 year ...
Rear sway bar loose
tehA8PIMP
01-15-2005 07:47 PM
