Strange behavior on RPM and Tranny. Scary!!
97 A8 w 135k mi. I was driving back home the speed will not reduce even the accelerator pedal was off and RPM just going up. Seems tranny was shifting radically too. I came to stop sign and tranny down shifted itself while depressing the acc pedal.
Finally,I stopped the car and put the gear in nutral, the rpm when sky rocketing I had to shut the car off. Started again and it was ideling in fluctuation....
This is scary. What could possibly affecting this symptom??
My tranny was replaced at 109k and tune up(plugs and fuel filter) done.
It seemed that accelerator pedal was kind of wierd when applying pressure to it. But also the tranny was acting up it was just shifting by itself shen stopped. Maybe this is all related?
Do you park your car outside or in the garage? I would bet outside.
If you look through all the forums here, as usualy, you will see A LOT of posts of problems when the ambient temperature drops to 0 F or below.
Not hard to believe.....it would be hard to engineer something that has to work in such a high range of temps with no problems.
It was a squirrel stuck between the trodle body and the top cover. He was looking for a warm place and get stuck. He said, it was hard to press the pedal and it did not come back.
