Sponsored by:
Sponsored by:
sunroof problem after dead battery
Old 09-16-2004, 08:47 AM
New Member
milman1096's Avatar
Default sunroof problem after dead battery
sunroof opened by itself after dead battery was charged. Now it won't close. The switch will not close or open the sunroof. Help.
Old 09-16-2004, 09:50 AM
Junior Member
A8-911-Odyssey's Avatar
Default This happened to me...
...when I swapped batteries last year.
The sunroof would not open or close all the way but it did move from half way open to fully open with the switch.
I mannually cranked the sunroof closed and then restarted the car. It worked from then on. The manual crank closure is in the panel for the sunroof, I think it uses an allen wrench for manula closure.
Hope this helps!
Old 09-16-2004, 10:20 AM
New Member
EFosshaug's Avatar
Default Re: sunroof problem after dead battery
This has happened to me as well. Take the fuse out and put it in again, and the sunroof will operate normally.
Erik
Old 09-16-2004, 03:13 PM
99A8Q's Avatar
Default I had a similar problem...
At the end of the OEM battery's life, I would put the charger on and sometimes the roof would just open itself all the way (one time the car was full of snow when I came out in the am!) and the first couple of times I thought the damn car was possessed. But the sunroof switch would then work essentially in reverse. Since the car was parked with the dial in the "closed" position and the roof was now open wide, turning it toward "lift" would cause it to close about a third of the way. Moving toward "open" would just strain the motor trying to open it further. Here's what worked for me:
1) drop the switch panel (easy--only 2 screws) cover, and disconnect the connector-- 3 prong keyed
2) rotate the switch to the full open position (where the roof actually was positioned)
3) reconnect the connector
It would then function normally. I haven't had to do it since the new battery, but it worked at least 5 times for me. Sorry this is so windy...good luck
closed loop
Audi Original "S" Cars
05-18-2009 06:10 PM
Zumkopf
09-30-2007 04:52 PM
saabSean
12
06-29-2006 07:16 AM
Chi-Town Lite Foot
01-16-2006 08:39 PM
Leo Shipman
03-18-2002 06:56 PM
Quick Reply: sunroof problem after dead battery
