throttle valve position
The car is showing excessive fuel consumption around town. There are no error codes showing up but the dealer said the throttle valve is at 8 degrees! Suggested I use carby cleaner and this should fix. It didn't. Any ideas? To me there is insufficient throttle response and clearly if the valve(flap)is in the wrong position, the ECU is probably being fooled?
It has a measuring block for it, you need to watch it as you drive down the road. It sounds very odd that it's at 8%, I believe it's suppose to be less than 1% when the gas pedal is not depressed.
AudiSportB5S4
09-18-2008 11:40 AM
PhunkFX
06-10-2007 11:58 AM
Too Cold NB1.8T
1.8T Discussion
08-22-2005 04:53 PM
Scott Evil
Performance and Tuning
07-25-2002 05:22 AM
Matt E.
06-24-2002 08:57 PM
