Time for a Timing Belt...
My 2002 S8 just turned over 100k miles, time for a timing belt.
Got a quote from a local specialty shop in the Houston area for "about" $2,000. Quote includes belt, new metal-impeller water pump, tensioners, etc.
Does the price seem reasonable to you? Only point of comparison that I have is a T-belt service on my 2004 A6 done about 3 years ago for about $1,600.
Appreciate your thoughts and thanks!
Thats alot of money, should be more like 1500$ parts and labor. its 7.9 hours, what 90$ an hour. A generous markup on parts for the shop would be like $600ish for the belt kit, $40-50 drive belt, $40-50 coolant and $35-50 thermostat, Shouldn't be 2000$ unless this place has crazy labor rate. Really consider a transmission service if it has not had one as part of your big 100k service.
much appreciated! Quote seemed a bit high, will check with a couple of other shops and compare.
Re: transmission service, the shop owner strongly recommended against it. I understand that there two schools of thought about the tranny service, and this may be reason to take my business elsewhere.
Changing atf on a "failing" or "symptom producing" trans has NEVER fixed anything. Old fluid does NOT produce symptoms or even reduce performance or, IMHO, shorten the life a transmission. It's gonna die when it's gonna die.
If you find dirty, burnt atf from a trans, it has already failed and new atf will only speed up it's demise. If working properly, a trans at 100K miles should have atf that does NOT smell burnt, still has color and nothing more than minute metal "sand" on the magnets. Changing the filter at high mileage is the only "preventive" maintenance that makes any sense. Old fluid still lubes and produces more than enough pressure to operate components in the trans.
There are countless documented accounts of trans's failing immediately after an atf change...esp those already with issues and/or burnt debris-filled atf.
I have never read or seen one shred of evidence that atf changes extend the life of any trans or fix any issue...only "theory" with NO real world evidence to back it up.
For every high mileage "success" story after regular atf changes, there are more to match it when NO atf service was ever performed.
An auto trans is gonna die when it's gonna die...and when it comes to the 5HP24a, they ALL die sooner or later...many well before they should...BY BAD DESIGN...NOT atf problems.
Cheers
Milehigh4.2
12
09-13-2006 06:33 AM
HX_Guy
03-25-2006 11:16 AM
Asicks2.7T
28
02-11-2005 12:49 PM
