Timing the 2OOO A8
Greetings Fellas,
I have a 2OOO A8 that's sick, has the flu really
bad. Need some help from you guys, here's the
info:
Monday 22March2010
13 Faults Found:
Misfire Detected on all cylinders except 6
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
17927 - Camshaft Adjustment; Bank 1: Malfunction
The above is the first scan from when I first got ahold
of the beast at the beginning of the year, now after re-
placing all coils and attempting on my own to adjust the
timing here's how it reads:
Monday,23,August,2010
16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Lost,,,,, need help, any ideas guys ?? Any help in the right
direction would sure be appreciated much. 972 322 4708
info:
Monday 22March2010
13 Faults Found:
I think all your problems may just lie with the ignition Immobilizer key. Get the key reprogrammed or reset it with vag-com or remove the instrument cluster, unplug/plug the ignition connector, recharge the battery or change a new one.
Cheers and good luck,
Louis
Louis
Flown
A4 (B7 Platform) Discussion
07-03-2018 12:16 PM
dohdies
09-24-2017 10:49 AM
