tip on demand part 1
stage 1 of my on-demand tip conversion is finished.
to summarise, i want to use my steering wheel tip buttons in an on-demand manner, like the later tip cars.
1) i have traced and confirmed that the wiring is as per the bentley.
2) i have connected supplementary wiring to the "tip up", "tip down", "tip recognition", and "tcm ground" wires.
the wiring diagram is below
<img src="http://pictureposter.audiworld.com/53706/tiptronic_tip_switch.jpg">
the wires required to connect to are:
a) tcm ground, brown/yellow in tcm wiring harness
b) tip recognition, brown/red - position 6, yellow 10-pin connector
c) tip down, yellow/blue - position 7, yellow 10-pin connector
d) tip up, yellow/green - position 5, blue 10-pin connector
<img src="http://pictureposter.audiworld.com/53706/tip_mod_plug_1.jpg">
the photo above shows the tapping of the feeds from the 2 10-pin connectors (the taps are blue)
<img src="http://pictureposter.audiworld.com/53706/tip_mod_plug_2.jpg">
this photo shows the 4-pin socket which i will use for the relay plate once i've sourced the relay.
3) findings:
- tip recognition is asserted all the time the gear lever is in the tip gate; it is not, as thought, a momentary switch
- tip up and down hold 12v until they are asserted
- with the tranny in "d", closing my "tip recognition" circuit (i.e. yellow 10-pin/6 to tcm ground) is sufficient for the steering wheel buttons to work
- using my simple "pin-outs" i can change gear using a momentary switch
- with the tranny not in "d", closing the "tip recognition" circuit has no effect
- leaving the "tip recognition" circuit closed and moving the gear lever from "d" will cause the tcm to log a code (tip recognition short to ground)
- in this case the tip will no longer work until the tranny is reset to park.
4) conclusions and next steps
- a simple relay to assert and hold tip recognition when the steering wheel tip buttons are hit will suffice for my purposes.
- i will need to work on the relay setup which is my next step
any suggestions or help is welcome.
3) findings:
If you use this wiring, you can activate tiptronic with either wheel buttons. If you press up button, it will switch to tiptronic and the car will be in a current gear that the D auto had. If you press the down button, it will switch to tiptronic and down shift at the same time.<ul><li><a href="https://forums.audiworld.com/a8/msgs/120058.phtml">https://forums.audiworld.com/a8/msgs/120058.phtml</a</li></ul>
sizquik
03-13-2008 07:12 AM
DryHeat 2.7T
01-10-2002 01:13 PM
